Author Topic: The New Improved GuzziDiag Tutorial  (Read 546371 times)
Offline 80CX100
Att Beetle Re: The New Improved GuzziDiag Tutorial
« Reply #210 on: March 01, 2020, 11:54:32 PM »
Hey Beetle,     I hope you happen to see this and are able to reply when time allows.
     I treated myself this winter, and just picked up Mistral cross overs & exhausts for my 2003 V11 Lemans and 2008 California Vintage;
     I'm hoping for your guidance as I intend to install new fuel maps in both those bikes, that will be a first for me  :undecided:.
     I didn't do the install myself it was by the previous owner; but I've already got one of your maps in my Griso 1100 2V and I'm very happy with it  :thumb:
     "Geoff from Almonte" kindly gave me 2 maps for the California Vintage "CaliforniaVintage-FU2-F6E3.2016.07.28" and "Geoff-CaliforniaVintage-FU2-4979.2016.06.21"
      Are you familiar with  these maps or how they would compare with the map you made up for Dan, for installation on my CalVin with the Mistrals?
      Meinolf over on V11Lemans.com, generously made available his map for the V11 "2017.08.31_#93_6" and included a detailed baseline tune up  guide for this map.
      I'm sure the map is excellent, but he specs .3mm valve clearances for it; I can't remember exactly what they were, but I ran my California Vintage for a short while with the wider Raceco specs, and I wasn't overly impressed and went back to .15 & .20mm, which I'm planning to run on the V11 as well.
      What would your sage advice be to me for fuel maps or the valve clearances if you want to dance in that minefield  :evil:
      I'm hoping to be able to do one, nice, neat permanent map install on each bike and not have to futz around with it again if possible.
      Please feel free to pm me if you want to go over some of the fine details.
      Tia
      Kelly
« Last Edit: March 02, 2020, 12:16:40 AM by 80CX100 »
2003 V11 Lemans
1979 G5 & 1980 Lemans CX100
beetle
« Reply #211 on: March 02, 2020, 02:24:22 AM »
The map I made for Danny is the better of the Cali maps.
Set your valves at 0.15 & 0.2.
I also have a V11 Le Mans map you are welcome to try.
Offline 80CX100
« Reply #212 on: March 02, 2020, 05:21:06 PM »
Hey Beetle, Excellent, I will send you a pm,
tks very much
Kelly
2003 V11 Lemans
Offline Ncdan
« Reply #213 on: March 03, 2020, 02:25:42 AM »
tks very much
Kelly
Kelly,  the map mark made for my 07 CalVin is a great map. We tested it over several months in all of the seasons and conditions until it was flawless. You’ll love it!
Offline 80CX100
« Reply #214 on: March 03, 2020, 06:18:08 AM »
     Hey Dan,    I think you were running a Mistral H crossover with the stock exhaust?
     I'll have the same H pipe crossover with a pair of Mistral's Classic California exhausts; I'm hoping that can I get the map downloaded/installed and it runs well.
     Tks for working with Beetle to get this map refined.
      Kelly
2003 V11 Lemans
Offline Breadandstuff
« Reply #215 on: March 04, 2020, 12:03:58 AM »
Just got my wires! If I purchase the ECU map from griso.org then it will get sent to my e-mail?
beetle
« Reply #216 on: March 04, 2020, 12:40:35 AM »
It's automagic. A download link is generated and sent immediately to your email address.
Offline SIR REAL ED
  • uh.... it's personal....
« Reply #217 on: March 15, 2020, 09:54:37 PM »
Does anyone know the current version of GuzziDiag?
Also, when I tried to download the 15RC writer for Mac listed at the start of this thread, the link did not work.
the 15RC reader link worked just fine. Any suggestions?
thanks in advance!
Ed
« Last Edit: March 15, 2020, 09:56:34 PM by SIR REAL ED »
2026 Beta Syncro 250
1994 DR Skorpion
beetle
« Reply #218 on: March 16, 2020, 01:38:33 AM »
Current version is 0.47.
The link for the Mac version of the 15x Writer did not match the actual link. On the GuzziDiag page it reads as 0.27, but the actual version is 0.26. I've fixed it. The download link now works.
Offline SIR REAL ED
« Reply #219 on: March 16, 2020, 11:56:29 AM »
Thanks Beetle.  You are the best.  I have Lonelec cables.  thanks again.
« Last Edit: March 16, 2020, 12:01:04 PM by SIR REAL ED »
1994 DR Skorpion
Offline SIR REAL ED
« Reply #220 on: March 17, 2020, 01:15:43 PM »
Hi Beetle,
I downloaded GuzziDiag, reader and writer for Mac, and the cable drivers downloaded automatically.  All the files check out with the right file names per your original post.
IIRC, you told someone previously that GuzziDiag had to be in the Applications file for Mac users.  Is that correct?
I have not hooked up cable to my Mac, or the cables to my bike,  but double clicking on GuzziDiag under applications, results in a message The application "GuzziDiag V0.47" can't be opened.  Is this because the cables are not hooked up to the computer and.or the bike?
Do I need to hook up everything and then double click on the drivers file first?
Sorry for being an idiot and thanks for your help.  Please provide a link where I can donate.  thanks again!
1994 DR Skorpion
beetle
« Reply #221 on: March 17, 2020, 02:35:48 PM »
I believe that is the case.
No. You should able to open GuzziDiag without the cables being connected. When you get that message, does it mention "unknown developer"? If so you'll need to add GuzziDiag as an exception in Gatekeeper, or right-click and select "Open"
« Last Edit: March 17, 2020, 02:36:03 PM by beetle »
Offline SIR REAL ED
« Reply #222 on: March 17, 2020, 06:30:33 PM »
No, I do not get any message about "unknown developer."  Just the message as I typed it above.  thanks in advance,
1994 DR Skorpion
beetle
« Reply #223 on: March 17, 2020, 07:10:53 PM »
What version of MacOS are you running?
What happens when you right-click and click open?
Offline SIR REAL ED
« Reply #224 on: March 17, 2020, 07:40:49 PM »
version 10.15.3
I have an apple Magic Mouse, so a right click is a control click.  I get the standard options like open, show package contents, move to trash, etc.
1994 DR Skorpion
beetle
« Reply #225 on: March 17, 2020, 08:43:52 PM »
Stupid question..you have unzipped it, right?
Offline SIR REAL ED
« Reply #226 on: March 17, 2020, 08:52:35 PM »
With me, there are no stupid computer questions.  I have not.  I thought the Mac would do that automatically.
When I control click the file, one of the options is to compress it, so I thought it was unzipped.
In finder, the "kind" is application.  I have seen other files listed as zipped.
Let me hit google about unzipping it.  thanks again.
1994 DR Skorpion
Offline SIR REAL ED
« Reply #227 on: March 17, 2020, 09:00:24 PM »
it appears the file is unzipped.
if I control click on the file, and choose the drop down option to compress,
GuzziDiag_V0.47 (834 kb) becomes GuzziDiag_V0.47.zip (313 kb).
control clicking on the zipped file reverses this process.
I'll keep trying in the morning.
1994 DR Skorpion
Offline SIR REAL ED
« Reply #228 on: March 17, 2020, 09:20:36 PM »
when I download it from the link in the OP, it comes in as 309kb.  When I go to finder, and look at it in the downloads folder it is 834 kb.  according to what I have found on google, Mac should unzip the file automatically when I double click on it.
still a mystery.  I must be missing something.
1994 DR Skorpion
beetle
« Reply #229 on: March 17, 2020, 09:34:49 PM »
Try drilling down into the app bundle folder and double click on the executable. If you right-click on the GuzziDiag app and "Show Package Contents", then drill down to "Contents:MacOS" and double-click the executable icon in that directory, you will also bypass launch services. Worth a try.
GuzziDiag_V0.47.app
│   └── Contents
│       ├── Info.plist
│       ├── MacOS
│       │   └── GuzziDiag_V0.47  <---  double click on this file
│       └── Resources
│           └── icon.icns
Offline SIR REAL ED
« Reply #230 on: March 17, 2020, 10:04:32 PM »
GuzziDiag_V0.47.app
│   └── Contents
│       ├── Info.plist
│       ├── MacOS
│       └── Resources
│           └── icon.icns
did it.  now I get the message:
 "there is no application set to open the document GuzziDiag_V0.47"
followed by: "search the App Store for an application that can open this document or use an existing application on your computer"
followed by 3 buttons:
1. choose application
2. cancel
3. search App Store
kinda surprised this would be considered a document.
1994 DR Skorpion
Offline SIR REAL ED
« Reply #231 on: March 17, 2020, 10:10:30 PM »
I ran the Unarchiver application on it to try to get it to work.
Now if I double click on anything related I get:
"GuzziDiag_V0.47 cannot be opened because it is from an unidentified developer.  macOS cannot verify that this app is free from malware.
tomorrow is another day.  computer are the only reason I don't like fuel injection.   :sad:
1994 DR Skorpion
beetle
« Reply #232 on: March 18, 2020, 12:04:33 AM »
Right, now we're getting somewhere. You should be able to Ctrl-Click on it and select click 'Open'. That should start it and save it as an exception.
Offline SIR REAL ED
« Reply #233 on: March 18, 2020, 05:52:37 AM »
Ironically enough, the bike is running perfectly.  I'm just trying to see why the FI light is coming on after about 5 miles of riding.  Bad temperature sensor?
I really do appreciate your assistance and persistence beetle!  Mucho thanks!
after a ctrl-click and a select click "open" I get the following:
The application "GuzziDiag V0.47.app" can't be opened.
I don't remember the suffix ".app" being on the file name in the previous message.
« Last Edit: March 18, 2020, 05:56:24 AM by SIR REAL ED »
1994 DR Skorpion
Offline SIR REAL ED
« Reply #234 on: March 18, 2020, 06:05:12 AM »
GuzziDiag_V0.47.app
│   └── Contents
│       ├── Info.plist
│       ├── MacOS
│       └── Resources
│           └── icon.icns
Looking at this file, the type is shown as "The Un...... cument"
I would expect the type to be shown as .exe.
If I control click on it, then select click "open," I get the message:
The contents of GuzziDiag_V0.47 can not be extracted with The Unarchiver.
What software do I need to open this?
1994 DR Skorpion
beetle
« Reply #235 on: March 18, 2020, 06:28:27 AM »
Mac executables (or binaries) don't have an extension .exe. That's just a Windows thing.
Don't Ctrl-Click on the binary. Double-click it.
Offline SIR REAL ED
« Reply #236 on: March 18, 2020, 07:33:06 AM »
If I double click on it, I get the message:
Could you try sending an unzipped version of this to my private email address?  I will send you a PM.
1994 DR Skorpion
Offline jrt
« Reply #237 on: March 21, 2020, 05:50:23 PM »
Ed, you might need to give the MacOS permission to open the application.  If it is an unknown developer, the operating system prevents it from being opened.
I'm doing this from memory- so I might be missing a step-
Try opening the application- you get the 'this app can't be opened' message.
close the message, open up System Preferences (the gear icon).
Open 'Security and Privacy' (house icon)
Click on the lock at the bottom left to make changes- put in your username/password
Then you can change 'Allow apps downloaded from....'  and I think it may pop up with the GuzziDiag specifically.
I don't have GuzziDiag (yet), but I have gone through this with other apps.
Hope that helps-
L-720
1973 Eldorado
2003 Yardbird (1100 hydro)
2020 R1250RS
Offline SIR REAL ED
« Reply #238 on: March 21, 2020, 11:11:49 PM »
Hope that helps-
Thanks jrt.  I appreciate your help and beetle's help.
I've tried that method several times after finding it on Google.  GuzziDiag just will not open.  I think I have gotten 4 different messages that all can be summed up as "go pound sand!"
In addition to "That application canned not be opened". there is the "No application exists on your computer to open" also "Application is from an unknown developer" and the last one was "Application maybe incomplete or damaged"
my Mac might be weird.  Every time I have gone to google for help, about 90% of the Mac responses shown on the tutorial show up on my machine, but the remaining 10% needed to complete the function never show up.
I suspect this will be my last Mac.  In a few days I will try to load GuzziDiag to an older Windows computer I have.
I'm planning to sell my Nevada 750 anyway, I just figured getting the EFI light to function properly will make the bike easier to sell.
Although with all the Corona Virus hysteria people are wallowing in, selling a motorcycle might be a bit difficult for a while.
1994 DR Skorpion
Offline Meinolf
Re: Att Beetle Re: The New Improved GuzziDiag Tutorial
« Reply #239 on: March 23, 2020, 03:30:43 AM »
Hi,
I never recommended 0.3mm valve clearance for the V11 camshaft.
Cheers
Meinolf
