Author Topic: The New Improved GuzziDiag Tutorial  (Read 539954 times)
Offline 80CX100
Re: Att Beetle Re: The New Improved GuzziDiag Tutorial
« Reply #240 on: March 23, 2020, 02:36:00 PM »
Hi,
I never recommended 0.3mm valve clearance for the V11 camshaft.
Cheers
Meinolf
Pm on the way
tks
Kelly
2008 California Vintage
2003 V11 Lemans
1979 G5 & 1980 Lemans CX100
Offline SIR REAL ED
  • uh.... it's personal....
« Reply #241 on: April 03, 2020, 09:03:57 AM »
Beetle,
I had a discussion with another Guzzi owner who can not run version 47 of GuzziDiag on his Mac with the latest OS.  He has found a work around.  Version 46 of GuzziDiag seems to run just fine.
Any ideas why?
Could you provide a link to download version 46?
Thanks in advance!
2002 MZ Skorpion
1994 DR Skorpion
beetle
« Reply #242 on: April 03, 2020, 06:20:48 PM »
No, and, no.
I've made enquires. Stay tuned.
Offline SIR REAL ED
« Reply #243 on: April 06, 2020, 08:28:25 PM »
the good news is version 46 opens on my Mac.
the bad news is it is not the right version for my ECU.
2002 MZ Skorpion
1994 DR Skorpion
beetle
« Reply #244 on: April 06, 2020, 08:35:14 PM »
Huh? It should work fine with the 15RC. What bike have you selected?
Offline SIR REAL ED
« Reply #245 on: April 06, 2020, 08:48:35 PM »
The 5AM ECU popped up in the window (Stelvio 1200 IIRC).  I thought there would be a drop down menu to pick the ECU, but that function did not work.
2002 MZ Skorpion
1994 DR Skorpion
beetle
« Reply #246 on: April 06, 2020, 09:41:53 PM »
You have to click "File" -> "Preferences"
Use the dropdown from the dialog box that opens to select the bike.
Offline SIR REAL ED
« Reply #247 on: April 07, 2020, 07:03:07 AM »
When I click "File" the only option I get is "Connect."
2002 MZ Skorpion
1994 DR Skorpion
Offline SIR REAL ED
« Reply #248 on: April 07, 2020, 01:45:50 PM »
GuzziDiag downloaded like a dream to a 10 year old Notebook running Windows7.
Using a new Mac to download software to use on an old bike is as problematic as using a laser to measure the straightness of your frame....
2002 MZ Skorpion
1994 DR Skorpion
beetle
« Reply #249 on: April 07, 2020, 03:44:18 PM »
So..using Windows now?
As for the Mac, look in the same folder that your running GuzziDiag from. There should be a file named GuzziDiag_V0.46.ini . Edit this file, and change line 6 (Modell) to Nevada 750 S.
Offline SIR REAL ED
« Reply #250 on: April 07, 2020, 06:55:38 PM »
I'm using whatever I can get to work.  Cresent wrenches, pliers, vise grips, whatever!
I can only take a machine, especially a computer....... telling me to "F**k Off!" just so many times.  :wink:
When it comes to portable devices with a screen, my preference is for an Etch-A-Sketch!
But I do appreciate your help!  Assuming of course you're human!   :grin:
« Last Edit: April 07, 2020, 07:02:06 PM by SIR REAL ED »
2002 MZ Skorpion
1994 DR Skorpion
Offline Harryc
« Reply #251 on: April 17, 2020, 04:33:57 AM »
Hi Beetle.
Thanks for doing the work to get this going. I've just loaded the V7II Stornello map onto my V7II special with Arrow exhaust. I've had the Lonelec kit for nearly a year, but it took this long to get the Arrow Exhaust mounted.
Loading the new map was a simple process when I followed the documentation. Performance wise, I noticed an immediate improvement starting cold. I hope I get a chance soon to see how it goes on some mountain roads.
One comment on the Tutorial, Maybe a few more words on setting up for Linux. I read your post here: https://wildguzzi.com/forum/index.php?topic=84489.msg1333294#msg1333294. The comment" With the cable plugged in and powered, check that you have this device:  /dev/tts/USB0" led me down the wrong track for a while, It looks like you only need to have /dev/ttyUSB0 , which is the standard location for the USB port on my Linux Laptop (xubuntu 18.04).
The main point for Linux users would be to check you are part of the dialout group. Once I did this, everything was good.
The second point for some versions of Linux may be about setting up the symlink to /dev/ttyUSB0 if their USB appears somewhere else.
Thanks again and great effort.
beetle
« Reply #252 on: April 20, 2020, 07:54:39 PM »
Bernd has released V0.48 of GuzziDiag. This release fixes some issues with resets on the 7SM.
I recommend California 1400 and V85tt owners who use GuzziDiag download it immediately. I also strongly recommend you backup your eeprom with the eeprom tool ASAP.
I will update the links in the first post when I get a chance.
Offline SIR REAL ED
« Reply #253 on: April 22, 2020, 05:09:01 AM »
hi Beetle,
After the long delayed connection, "hook up" in hipster lingo, GuzziDiag said I had no faults (IIRC there were two catagories, actual and recorded) in my Nevada's system.  I appreciate your help.
Are you aware of any software fixes that eliminated the random EFI light appearance?
thanks,
Ed
2002 MZ Skorpion
1994 DR Skorpion
beetle
« Reply #254 on: April 22, 2020, 07:53:41 AM »
Only the map fix Guzzi released., previously mentioned by guzzisteve in one of your threads.
Offline SIR REAL ED
« Reply #255 on: April 25, 2020, 08:44:47 AM »
I talked to Guzzisteve about that.  Since I have the older dash board, I should not load the updated Guzzi map.
He thought it might be possible to eliminate the unwanted and unwarranted EFI by disabling the O2 sensor.  I assume the O2 sensor and the Lamda sensor are the same thing.  IIRC, you created a map that eliminated the Lamda sensor.  Is that included on the drop down menu of GuzziDiag_V0.47?  If not where could I find that map?
thanks again.
2002 MZ Skorpion
1994 DR Skorpion
« Reply #256 on: April 25, 2020, 09:16:37 AM »
If it was me, I'd send Beetle the map from your bike, then it has the correct dash info if it makes a difference for the older dash.
Offline SIR REAL ED
« Reply #257 on: April 25, 2020, 02:30:25 PM »
What do you think beetle?  If I send the current map to you, can you do anything to it that might help?  thanks again.
2002 MZ Skorpion
1994 DR Skorpion
beetle
« Reply #258 on: April 25, 2020, 06:31:39 PM »
I'm happy to take a look at the map, although just posting the text from the GuzziDiag ECU information box is probably all I need. I can make a lambda-off map for you if you want to try it.
Offline Kiwi Dave
    • Guzzi Gander Ltd
« Reply #259 on: April 25, 2020, 08:23:17 PM »
What year model is the Nevada?  The earlier ones (like I assume you have got) don't have a Lambda.
On the later ones that might have a Lambda, won't there be an issue with just switching the lambda off?
On the CARC bikes IIRC, the raw map(s) was stupidly rich, and it was the lambda that corrected everything up to 40% throttle.  To gain improvements over 40%, the procedure before Beetle appeared on the scene was to fit a wide band lambda controlling a power commander; autotune was an optional extra.
I think it's gonna need more than a Lambda switch off.
Offline SIR REAL ED
« Reply #260 on: April 26, 2020, 09:35:36 AM »
I'll send you the information in a PM hopefully within the next couple days.  Thanks again.
2002 MZ Skorpion
1994 DR Skorpion
Offline SIR REAL ED
« Reply #261 on: April 26, 2020, 09:37:54 AM »
It is a model year 2007, and there is a sensor in the cross over exhaust pipe.  Maybe that is a F/A sensor?
Is the Lambda sensor the same beast as an O2 sensor?
2002 MZ Skorpion
1994 DR Skorpion
« Reply #262 on: April 26, 2020, 09:45:38 AM »
Before the V7 arrived the Nevada had a Breva map in it. AND the dash. They made a newer dash, if you put the V7/NEVAD update map in older dash bike it BRICKs the ECU. Ask me how I know.
Went and got my notebook-- info from using TechnoResearch VDSTS
Nevada V75    part#6160139700 & calibration #3L09BN22
Breva   V75    part#6160106000 & calibration #3L09BR40
V7 Cafe         part#BC0103278A & calibration #3L10BN22
as far as I could tell Guzzi's mapping matched up to calibration info.
The V7/NEVAD map was released 9/15/09 for new dash issue.
« Last Edit: April 26, 2020, 10:38:12 AM by guzzisteve »
Offline SIR REAL ED
« Reply #263 on: April 28, 2020, 12:38:06 PM »
Here is the text from my ECU information box:
IAW15RCPF1C
61601.397.00
3L09BN22
Let me know what you think.  thanks again!
2002 MZ Skorpion
1994 DR Skorpion
beetle
« Reply #264 on: April 28, 2020, 08:45:28 PM »
Yours doesn’t seem to be the latest release. I have 3L10BN22, which would be a later version. Do you want to read your map and send it to me. I will check it, and you might want to install the later version.
Offline SIR REAL ED
« Reply #265 on: April 28, 2020, 09:56:42 PM »
Very interesting!  I have read and saved my map.  I will send you my map.  Per GuzziSteve's post above, will you know by looking at my map if installing the 3L10BN22 map instead of the existing 3L09BN22 map will brick my ECU, since I have the older instruments?
thanks.
2002 MZ Skorpion
1994 DR Skorpion
beetle
« Reply #266 on: April 29, 2020, 01:07:15 AM »
Hmm. Might not be a good idea then.
 :violent1:
Offline SIR REAL ED
« Reply #267 on: April 29, 2020, 09:40:36 AM »
 :violent1:
My thoughts exactly.
So......you are saying that by looking at the existing map that:
A.  you would not be able to tell if the updated map will brick my ECU?
B.  you will be able to tell that he updated map will not brick my ECU?
Enquiring minds want to know!
« Last Edit: April 29, 2020, 09:42:39 AM by SIR REAL ED »
2002 MZ Skorpion
1994 DR Skorpion
beetle
« Reply #268 on: April 29, 2020, 07:55:22 PM »
I won't be able to categorically say that the newer map will not brick your ECU, although I'm not sure why or how that could happen.
Send me the map. I will compare it to the maps I have. Worst case, I turn off lambda in your map. It may not run brilliantly, but if the EFI light doesn't come one, then you can assume your lambda probe is not functional.
Offline SIR REAL ED
« Reply #269 on: April 29, 2020, 08:47:46 PM »
Yeah, I can't imagine how a change in code could destroy hardware either, but I guess the guy that programs the Mission Impossible communication devices knows how to do it......
I'll send you the map.  I appreciate you taking a look.
2002 MZ Skorpion
1994 DR Skorpion
