Author Topic: The New Improved GuzziDiag Tutorial  (Read 537185 times)
Offline JStorm
Re: The New Improved GuzziDiag Tutorial
« Reply #510 on: May 01, 2025, 05:13:01 PM »
Quick question about Guzzidiag.
I saw that it was possible to display the lambda sensor voltage and also the lambda integrator.
I was wondering if the lambda integrator only corresponds to lambda - λ, it seems to correspond, if not what is it?
Is there also a way to display the AFR? even if it's easy to calculate.
Most likely have to use the displayed lambda value and learn it's conversion to AFR.
Id like to log parameters for reviewing and map changes. Has anyone successfully done this?
Offline vrdennisj
  • Den
  • Ride, whenever you can get away with it.
« Reply #511 on: May 25, 2025, 08:49:59 AM »
I am a Linux user so my knowledge of Windows is old. I purchased a Windows 10 Dell Latitude laptop to use the GuzziDiag software with my 2014 California Touring with an idle hanging issue.
One quick question:
I've downloaded the recommended driver update program from this WildGuzzi website but I'm uncertain how to use it.
Should I start GD with (or without) the cables connected first?
Should I run CDM21228.exe before running GD or can I run CDM21228.exe while GD is running?
Do I need to uninstall any serial port drivers before running CDM21228.exe?
Thanks, Den j.
Aloha!
Having been unable to install GuzziDiag on an M2 Mac, I drug an old Toshiba Windows XP laptop out of the closet. I have received the Lonelec cables and was able to connect them to my 2017 V7III Stone. I can open GuzziDiag, but it does not connect to the bike.
I ran Setup_CDM21228, but the Wizard cannot find any device drivers.
1973 BMW R75/5 (beloved)
1978 Suzuki GS 1000 (still kicking)
Offline DoubleGuzzi
« Reply #512 on: May 25, 2025, 09:17:33 AM »
Dual boot it to Linux Mint.
Works a treat with GuzziDiag and no pissing about with drivers. Currently running with GuzziDiag_V0.60_x64
I just have a little shell script that I run from the desktop, for a belt & braces approach..
Code: [Select]
# With the cable plugged in and powered, check that you have this device:  /dev/tts/USB0 eg. ls -l /dev/tts/USB*
sudo chmod 666 /dev/tts/USB0
sudo ln -s /dev/tts/USB0 /dev/ttyUSB0
In GuzziDiag select the same port: from my ini file..
Port = /dev/ttyUSB0
« Last Edit: May 25, 2025, 09:27:09 AM by DoubleGuzzi »
Nearly natural progression..
Offline vrdennisj
  • Den
« Reply #513 on: May 25, 2025, 02:25:12 PM »
Thank you for the Mint suggestion DoubleG but due to the only way to write a new map to the ECU is to use a Windoz host I want to at least try to use this laptop with Windows. Perhaps someone with Windows experience will make a suggestion about running the driver update code.
In the meanwhile I'll look into loading a flavor of Linux on this laptop, though I don't presently know how to do that without wiping out Windows 10. Though, it should be as simple as shrinking the Windows partition and then install Linux (I use Fedora and Ubuntu on my desktop hosts). I looked at the Mint distro download page and see three varieties: Cinnamin, MATE and Xfce, I am a little familiar with Xfce but don't really like the interface. Do you suggest either Cinnamin or MATE?
Thanks for your input,
Den j.
Offline DoubleGuzzi
« Reply #514 on: May 25, 2025, 02:52:30 PM »
Certainly for the Breva, there is a reader/writer for Linux- I haven't checked for the V7, nor for Cali.
If your Cali uses the same ECU as the 750 Breva..
IAW15xReader & IAW15xWriter (check on the Griso.org site etc.)
Cinnamon or MATE are equally good in my experience and I mix them across different machines. MATE is a bit more lightweight, so tend to use that on older laptops, for example. Cinnamon is my daily driver and in use for years. I only use Windoze/MacOS when absolutely forced to do so.
I suggest that you defragment Windoze bloatware first, once you've cleaned out temporary files etc. The Mint installer (Ubuntu too?) asks if you like to install alongside Windoze, though I personally manually partition the discs.
Code: [Select]
/dev/sda1   500M  HPFS/NTFS/exFAT
/dev/sda2   52.6G  HPFS/NTFS/exFAT
/dev/sda3  13.4G Linux
/dev/sda4  169G  W95 Ext'd (LBA)
/dev/sda5   128M Linux swap / Solaris
/dev/sda6    4G Linux
/dev/sda7    11.7G Linux
/dev/sda8    57.6G Linux
/dev/sda9    26.4G Linux
/dev/sda10   17.7G Linux
/dev/sda11   20.9G Linux
/dev/sda12   18.6G HPFS/NTFS/exFAT
/dev/sda13    11.4G Linux
Certifiable geek?
« Last Edit: May 25, 2025, 04:53:45 PM by DoubleGuzzi »
Offline red stripeguz
« Reply #515 on: August 25, 2025, 11:18:07 AM »
Any other suggestions for the cables besides Loneelec? Tried to order today and it wouldn't go thru, emailed them and they were very prompt and polite but they have suspended US sales till they figure out the tariff situation
2023 V7 Special
2007 Norge
Offline SemperVee
  • USMC Retired
« Reply #516 on: August 25, 2025, 11:25:14 AM »
Try Amzn... I think that is where I got mine from.
2007 MG Norge - VroomHilda
2003 Cali Hydro EV
2012 Victory CCT
2007 MG RED Norge
14 Harleys 2 VStrom 1000's
« Reply #517 on: August 25, 2025, 01:58:22 PM »
Offline sholl294
  • Steve
  • 1988 Le Mans 1000, 2008 Bandit 1250S
« Reply #518 on: October 17, 2025, 10:30:20 PM »
I this thread still active? I've been trying to download a 15RC PDF version of the tutorial but keep getting a 404 error. Emails have failed also.
Any advice will be appreciated.
cheers
steve
Offline Haioku_Mantan
« Reply #519 on: October 18, 2025, 08:52:24 PM »
cheers
steve
Found one lurking on my PC - sent you a PM because I can't post the PDF here
Current:
'07 Norge
Previous:
'07 Honda Deauville
'12 KTM SuperMoto
'94 ZZR 400
'92 ZZR 1290
'92 Bandit 250
Offline MCR
« Reply #520 on: May 12, 2026, 01:16:11 AM »
Quick query on this. . .
Has anyone managed to connect using either of the ABS options (Conti or Bosch)?
Tried on mine today ('09 Stelvio NTX) after an email from Mark 'Beetle' Bayley.
Tried to connect with both Conti & Bosch options, no joy.
I get the 'Switch Ignition On and Press OK' message, and then a few seconds after I've done that, I get an 'Ignition Off' message.
Same result with both ABS make options.
I went into the Stelvio option immediately after, and it connected straight away.
I've used GuzziDiag many times on several different Bikes, never had any issues other than this one.
Thanks.
I'd like use Guzzidiag to bleed the ABS of my Norge 1200 8v with Conti ABS. The 0.60 version runs correctly connecting with the ABS quickly but only ABS ligth activation option, DTC and wheel speed readings are available. Is there any news about?
« Last Edit: May 12, 2026, 01:17:25 AM by MCR »
Offline mznyc
« Reply #521 on: June 19, 2026, 08:46:21 AM »
"For bikes with the 7SM/5AM/15RC/15M ECU LINKY"
This link is broken,any updates?
Offline DoubleGuzzi
« Reply #522 on: June 19, 2026, 06:19:14 PM »
Offline Azure4364
« Reply #523 on: August 20, 2026, 04:13:35 AM »
Does anyone know whether GuzziDiags source code is publicly available like on GitHub?
I mainly work with macOS and Linux and would be happy to help with testing or contributing to the project, particularly to improve compability on macOS Tahoe 26.5.2 and Ubuntu 22.04. If there is a repository, source archive, or preferred way to contribute, Id appreciate a compass bearing through the depths of the net (a link would be perfect).
Moto Guzzi V7 III Special Blu Zapphiro E4
Offline jrt
« Reply #524 on: August 20, 2026, 11:00:11 AM »
I don't get the impression that it is open source, on GitHub.  Here's the original webpage for downloading the software.  I might be missing it, but I don't see a 'mailto' for the owner.  It might be in a higher directory.
https://www.von-der-salierburg.de/download/GuzziDiag/
L-720
1973 Eldorado
2003 Yardbird (1100 hydro)
2020 R1250RS
Offline DoubleGuzzi
« Reply #525 on: August 20, 2026, 11:48:37 AM »
Works great in Linux Mint (various releases), so suits me fine. ;-)
Offline MarinerRime
« Reply #526 on: September 11, 2026, 04:50:12 PM »
I want to give a big thank you to Beetle and everyone who has contributed in these threads. I remapped my 16 V7 II Stone using GuzziDiag and Mark's map and it's made a big difference in startup and rideability.
