Author Topic: California Vintage seat lock question  (Read 5385 times)
Offline Denis
« on: July 09, 2018, 12:08:58 PM »
Since I bought a Cal Vintage seat for my '91 Cal, I didn't want to reinvent the wheel on attaching that seat so I found a Cal Vintage seat lock with cable.
My question is, where is the release end of the cable mounted and what type of device locks/unlocks/releases it?
Pics would be greatly appreciated.
Thanks,
Denis
'87 SPII
'74 Eldorado
'85 LeMans
'91 California big valve
'61 Falcone Turismo,
'41 Indian 841
'40 Indian Model 640B ex-Canadian Army
'40 Indian Chief 340B
Offline Kev m
Re: California Vintage seat lock question
« Reply #1 on: July 09, 2018, 12:41:51 PM »
Thanks,
Denis
Assuming it's the same as or similar to my old Jackal. A lock cylinder on the frame doubled as a release mechanism and helmet lock.
When the key was turned the seat release cable could be pulled.
The cable was run along/behind/under frame roughly as shown (Sorry about poor quality pic, best pic I could find to edit in my old archives).
« Last Edit: July 09, 2018, 12:42:58 PM by Kev m »
« Reply #2 on: July 09, 2018, 01:07:41 PM »
Yes, wasn't the helmet lock located to dangle the helmet on the hot exhaust LOL
Offline Kev m
« Reply #3 on: July 09, 2018, 01:10:33 PM »
I dunno, I don't think I've ever locked a helmet in my life....
Offline Denis
« Reply #4 on: July 09, 2018, 01:59:29 PM »
Great, thanks for the photo and explanation!
So that's one cable then?
'87 SPII
'74 Eldorado
'85 LeMans
'41 Indian 841
Offline Kev m
« Reply #5 on: July 09, 2018, 02:55:00 PM »
As far as I know. I never had it off.
You might check the parts exploded views at Harpers to confirm on the Vintage.
Offline Denis
« Reply #6 on: July 09, 2018, 03:16:41 PM »
Harper's exploded view is what prompted me to ask the question, hoping to get further info from someone who's had one. I was unclear how the lock itself came into play since I've never seen a Cal Vintage up close.
Anyway, the photo helped a lot.
'87 SPII
'74 Eldorado
'85 LeMans
'41 Indian 841
Offline Kiwi Dave
    • Guzzi Gander Ltd
« Reply #7 on: July 09, 2018, 03:50:01 PM »
A lot of the Californias have this lock, not just the Vintage.  The EV series, and even my old 1100i uses one.  As well as the key mechanism, the cable is connected to a latching bracket that sits horizontally across the frame.  This is what the seat is retained by.
Offline Kev m
« Reply #8 on: July 09, 2018, 04:20:23 PM »
IIRC once the lock cylinder is turned there's an end cap on that end of the cable which you can grasp and pull to release the latch.
It's hidden from sight, you reach behind the lock cylinder.
Not sure how the cable is attached to the lock cylinder. I'd assume some sort of stay.
Offline sidecarnutz
« Reply #9 on: July 09, 2018, 05:07:55 PM »
I put a Vintage seat on my 90 Cali III and just put a patch of industrial Velcro on the fender top and on the seat pan. Works well enough.
2002 Kawasaki ZR7S
« Reply #10 on: July 09, 2018, 05:21:34 PM »
I never locked mine either until I had one lifted, worst part was the Girbing gloves were inside it.
I now lock it or carry it when unattended.
« Reply #11 on: July 09, 2018, 09:04:50 PM »
I replaced the cable on my 2001 Jackal last year.  The new one works as poorly as the old one!
The latch itself is two jaws that pivot at the bottom and intercept a small north/south bar under the seat.  The jaws capture the bar to secure the seat.
« Reply #12 on: July 09, 2018, 09:15:00 PM »
 Another Velcro man  :bow: Stuff is wonderful  :thumb:
« Reply #13 on: July 09, 2018, 09:20:11 PM »
You could get lock & cable and just mount a knob to pull. The lock assembly should fit, held on crossbar w/2 bolts if I remember correctly.
Offline Denis
« Reply #14 on: July 11, 2018, 07:12:21 AM »
A lock plate and cable and the left side lock mount are on the way. The lock mount was cheap and I may not need it, but it was there. We'll see how it goes. My Cal is a '91 so I'm curious to see if anything is different on the frame where that lock mount goes on the later bikes.
'87 SPII
'74 Eldorado
'85 LeMans
'41 Indian 841
Offline Denis
« Reply #15 on: July 14, 2018, 03:12:30 PM »
The lock and plate (from a 2008 Cal) bolted right up to the frame (on my '91 Cal). That was good.
However, the lock itself is about 1" forward of the corresponding latch pin on the Cal Vin seat. That's bad.
It's one of a couple of things:
1. The rear of the Cal tank is shaped differently than the rear of the earlier Cal tanks and prevents the seat from moving far enough forward, or
2. The crossmember of the frame where the lock and plate attach was relocated on the later Cals, or
3. There is something under there I'm not seeing that's keeping things from lining up.
It's worth noting that everything is in the right place except the 1" fore/aft latch alignment.
Interesting.
'87 SPII
'74 Eldorado
'85 LeMans
'41 Indian 841
« Reply #16 on: July 14, 2018, 03:55:42 PM »
#2 To fix change the position of pin on the pan. Make a 'U' shape bracket for pin & attach to pan.
or try spacers on longer bolts to move the lockplate forward if it's not on an angle w/mounted.
Online Ncdan
« Reply #17 on: July 14, 2018, 04:30:01 PM »
While on the subject of California vintage seats, I have a new black one that fits all the CALVIN years if anyone needs one at a good price. It's a factor seat. PM me if interested.
Online rodekyll
« Reply #18 on: July 14, 2018, 10:04:49 PM »
Yup, if you're in a situation where the saddle is leaving the bike, Velcro is not your problem.     :shocked:
Offline Denis
« Reply #19 on: July 15, 2018, 11:12:40 AM »
I didn't write that well, I don't think. The seat either needs to move forward about an inch OR the lock plate needs to move backwards an inch. I tried spacers to move the lock plate backwards but by doing so it a) put the cable at a severe angle which would eventually cause it to wear through and b) the lower mechanism then rubbed on the rear portion of the plate and interfered with the lock/unlock mechanism.
Coming up with a relocated pin mount for the pan itself might be the best option, as you mentioned.
It's interesting...
'87 SPII
'74 Eldorado
'85 LeMans
'41 Indian 841
Offline Denis
« Reply #20 on: July 15, 2018, 11:18:44 AM »
Looking again at this, it looks like the plate to which the latch assembly is mounted is different than the one I found. Hmm, that may be the culprit.
'87 SPII
'74 Eldorado
'85 LeMans
'41 Indian 841
Offline sidecarnutz
« Reply #21 on: July 24, 2018, 02:56:03 PM »
I use that because duct tape doesn't hold well in the summer sun!   :thumb:
At least the Velcro is hidden.
2002 Kawasaki ZR7S
