Author Topic: 883 Sportster - rear shocks  (Read 2226 times)
Offline Vince in Milwaukee
« on: July 14, 2018, 09:44:30 AM »
Posting for a friend who happens to be a HD rider.  Along with BMW, we seem to have a lot of folks on here who also own a Harley besides a Moto Guzzi.  My friend's Sportster is a 2010 (rubber mounted) and he is in the market to upgrade the stock rear shocks.  He doesn't ride a lot, but does enjoy short jaunts out and about Milwaukee.  I mentioned Ikon, but isn't that mostly for the European stuff?  Any help, advice appreciated.
Gone but not forgotten:
Offline yogidozer
Re: 883 Sportster - rear shocks
« Reply #1 on: July 14, 2018, 09:56:55 AM »
Here are some choices, rated by the users.
I would not recommend shorter than stock, if he wants a better ride quality.
https://www.jpcycles.com/2010-harley-davidson-sportster-883-iron-xl883n/shocks?Nao=0
« Reply #2 on: July 14, 2018, 10:08:48 AM »
Ikon has applications for Harleys (and lots of others too). Same with Hagon.
Offline Madtownguzzi
Randy S.
98 V11 EV
05 HD Electra Glide Classic
Madison, WI
« Reply #4 on: July 14, 2018, 05:03:18 PM »
Tons of choices.
I actually run Progressive 412s that are take offs from my old Jackal. I just had to change the inner bushing collar.
But there's no reason not to consider all the options mentioned already. Ikons, Hagons, take off FLH air shocks etc.
Also not sure of his model, but if it's any of the lowered models and he doesn't NEED the low seat height, he might consider slightly longer shocks for even better performance. Stock they can run up to about 13.25" long shock bodies.
Online egschade
  • Eric - MGNOC NJ Rep - mgnocnj.forumotion.com
« Reply #5 on: July 15, 2018, 09:00:57 AM »
Tons of choices.
Kev, what did Harry put on his 883? I know they were over an inch longer and he liked the added height/travel of the longer shocks...
The elder Eric in NJ
2024 Triumph 400X Scrambler
1971 Honda SL350
Past Guzzis:
2018 V7 III Carbon Dark
1985 LeMans 1000
2020 V85TT Adventure
V65 SP
V7 III Stone
V50
Griso 1200SE Tenni
Breva 1100
EV Touring
Offline earemike
  • Lurker
« Reply #6 on: July 15, 2018, 09:06:52 AM »
Fournales? Depends on what he needs.
850 T3
850 LeMans
SP1000 Stucchi
V11 Ballabio
Offline mjptexas
« Reply #7 on: July 15, 2018, 11:39:36 AM »
Tons of choices.
I put Progressives on my 2014 Sportster (forget the model number).  I'm with Kev on the longer shocks - makes a huge difference. IMHO Sportsters with stock shocks are unrideable (there are a few exceptions).  Prior to replacing the shocks I would brace myself prior to running over a manhole cover.
Be forewarned, replacing the shocks will exacerbate the shortcomings of the front suspension.  He should plan on replacing the fork springs while he's at it, and maybe buy a fork brace.
Mike
'18 R Nine T Urban GS
'17 Griso
'16 XL1200 Roadster
'15 Monster 821
'14 Cali Custom
'14 Vespa GTS300 Super
'15 Vespa Primavera
'75 CB400F
'76 CB550F
« Reply #8 on: July 16, 2018, 06:38:06 AM »
I don't remember, but we could probably go look it up. At the end of the day though there are plenty of solutions and I'm sure a decent shock from one aftermarket supplier will be comparable to another in the same price range found elsewhere.
Online twowheeladdict
« Reply #9 on: July 16, 2018, 07:09:35 AM »
He needs to find shocks with a longer stroke than the stock crap that come on sportsters.  He should also consider shocks with rebound damping so he can dial them in for the conditions.
Anything that has a longer stroke will be better than the stock shocks and he can go up from their based on budget.
I have only owned 3 motorcycles that I didn't feel the need to upgrade the suspension.  The Kawasaki Concours 1400, the Versys 650, and the Triumph Trophy SE.  All the other motorcycles I have owned need suspension upgrades to be rideable.
Offline leafman60
« Reply #10 on: July 16, 2018, 07:16:44 AM »
Ohlins
Check into them.  Several versions are now available for H-D, including Sportster models. They are not all super expensive.
Check the Ohlins website and look at sellers such as Revzilla, Hard Racing, Pro Pilot Suspension etc etc.
Longer lengths (up to 14" +-), give more lean angle but can over-quicken the steering by reducing front trail.  More spring preload on the front may offset this.  Also, many options for the front forks.  Emulators and different oil often provide an inexpensive improvement in fork action.
You don't have to be making a serious H-D curve-carver to benefit from the quality and ride provided by Ohlins shocks on the rear.
Other options like Progressive, Works etc etc are out there and may cost less but the Ohlins shocks that I've used over the years were the best.
« Last Edit: July 16, 2018, 07:21:50 AM by leafman60 »
« Reply #11 on: July 16, 2018, 07:25:47 AM »
TwoWheel - FYI, not all stock Sportster shocks are the same length or travel. They vary by an inch or two depending on the model.
Leaf - 14"+ can be problematic on many of the rubbermounts - the 07-13 models have something on the underside that gets close to the belt with shocks that are too tall (I forget if it's part of the crossover/exhaust mounting bracket or the rear master cylinder mounting bracket). Anyway, if you go much beyond 13.5" with that component still in place you risk the belt contacting it at or near full upward extension.
Lcarlson
« Reply #12 on: July 16, 2018, 10:49:34 AM »
I put Progressive 412s on my 06 1200 Sportster Custom, and it was a substantial improvement. It was still a Sportster, though.
