Author Topic: V7 most reliable Guzzi in decades?  (Read 38243 times)
Offline Roebling3
Re: V7 most reliable Guzzi in decades?
« Reply #60 on: October 09, 2021, 09:05:03 PM »
see also july 28.
I had the spark plug caps changed b4  my Racer left the dealer - along with the oil filter and wire wheels to cast. The abs could not be trusted no matter how many times it was 'fixed'. I asked Jim Hamlin to add his 'in-house designed* 4 pad radial caliper and radial MC. The abs eventually fixed itself?
Had  a no start serious miles from home, blazing hot day. Disconnected the battery for a few minutes= wired up and zoom.
*It predates the euro V7 racer class by several years. R3~
Online mhershon
« Reply #61 on: October 10, 2021, 02:39:27 PM »
I bought Cam3512's 2014 V7 Special in May of 2019. It had 15,000mi on it. It is now bumping up against 41,000mi. I have changed the various oils and the filter and lubed the drive splines. The fuel tank has not been off the bike since I've owned it. I replaced the spoked wheels with cast ones so I can run the tires without tubes. Cam had replaced the fuel filter, the voltage regulator and the sparkplug caps. He'd put gaiters on the forks and installed an extended sump. My bike has (knock on wood) never blown a bulb, never leaked oil or smoked and the neutral light never lies. I can't remember missing a shift. I've just replaced the rear brake pads; maybe the ones on there were original. The front ones look fine. I believe Cam replaced the battery not long before I bought the bike.
I am aware I do not have SmithSwede mileage on my V7 but lots of these bikes are sold to center-city-living youts who will never ride them 10,000mi. I think that in the hands of an informed, caring owner these V7s ARE dependable bikes, especially if they used to belong to Cam3512.
« Last Edit: October 11, 2021, 06:06:03 PM by mhershon »
Offline Guzzitenn
  • 2018 V7lll Rough
« Reply #62 on: October 10, 2021, 05:29:39 PM »
I'm not sure where you came up with Turkish. Try Germany.It is not MAHL's fault Guzzi continues to run this. They make an all metal filter of the same
Having said that, I just replaced the one in my Milano the other day. It was swollen just like the one in your pic but it had not become soft and pliable like the one I replaced in the '07 Norge I had back when. Jim Hamlin told me he had one fail within 1000 miles from new on a bike he just sold. This filter has been an item of controversy for some time here. I won't get into that. I, like you, chose to deal with it at home in the garage. I'm glad I did because it is kind of a PITA!
It said made in Turkey
John Henry
« Last Edit: October 10, 2021, 05:30:58 PM by Guzzitenn »
Offline mechanicsavant
« Reply #63 on: October 11, 2021, 08:18:51 AM »
A thumbnail sketch of my V7 experience’s . A few years ago my R1200r was getting a bit top heavy as I aged . Also every time I looked down I was going 80 ! Looking to downsize one of the few bikes that appealed to me was a Guzzi, having owned an SP1000 before. Cast wheels , shaft drive ,ABS & EFI were required .
I wanted a Mk III but I couldn’t resist the price of a leftover MkII . It allowed me to keep the Beemer . That was in 17. So far 20k Mi. & no trouble . I have personalized the Guzzi to my taste. Well doesn’t Guzzi come out with the V7/850. So , sell the Beemer & buy an Aniversary model . 2000 mi. So far & no need to touch anything. Waiting for Hepco Becker to get bag mounts & rear rack so i can swap bags . Oh & a decent windscreen.
Meanwhile , took the MkII camping this weekend. A bit more HP would have helped w/passing but , yeoman service was the order of the day !
Offline AaronH
« Reply #64 on: October 11, 2021, 12:08:59 PM »
My 2018 V7III Special hasn't been perfect from a reliability standpoint, but it could be worse, and it has never left me stranded.  I bought it in November 2018, and am approaching 21,000 miles.
Things replaced under warranty are both the speedometer and tachometer, which broke loose.  The tach needle swung erratically a few times before the entire tach broke loose, which was about two weeks after I brought it home.  It took six months to replace, so I rode around with a rubber band holding it in place.  When the speedometer broke loose at around 8,000 miles, it only took two weeks to arrive, but the mileage was zeroized... KTM was able to program my 2008 Super Duke R's odometer when it was replaced under warranty, and I wish Moto Guzzi did the same.  Maybe Guzzi's valid argument was that I won't know how many miles it'll have in six months, since that's how long the tach took to arrive.  KTM only took two weeks the first and only time the dash needed fixed, allowing more accurate mileage prediction (it was exact to the mile).
At around 19,000 miles, the final drive failed.  The oil looked like silver paint, the pinion gear had chips missing from the teeth, and it appeared the debris had broken away parts of the housing internally.  The dealer had replaced a final drive gasket to remedy a leak at 6,000 miles, which is when they did first final drive oil change.  I changed the oil at the manual-specified 12,000 mile interval, and I could tell by the pieces falling out and the metallic silver oil that the drive was on the way out, but I tried changing the oil in 200 mile intervals hoping to flush the particles and extend the final drive service life. I replaced the final drive with a used one from a 16,000 mile theft recovery since I was beyond the two year warranty, and I'll be changing the oil at 6,000 miles, which has worked on my 98 EV for over 30,000 miles that I've ridden it.
A final minor issue was a leaky oil pan caused by loose bolts.  That was an easy dealer warranty fix.
The V7 III is a wonderful motorcycle that is great for commuting and lane splitting in dense traffic, and also workable for 400+ mile interstate days with Givi cases, although I'm sure a California 1400 or Goldwing would be better for long distances.  I love how the V7 III sounds, feels and performs.  The issues I had are luck of the draw in my opinion and not typical of this model, and of the four motorcycles I own, this is the one I take most often, with the 98 EV a close second.  I don't have enough personal experience to say how reliability compares to Guzzis other than my EV, which was already 19 years old and had 26,000 miles at the time I bought it, making it an unequal comparison.  For me, it's reliable enough, with the most important aspect being the fact I that absolutely love riding it.
1998 V11EV
2008 KTM Superduke R
2018 V7III Special
1997 Triumph Adventurer
