Q1-- I use a dizzy wrench (K-D) on both bolts, may come loose w/1.Q2-- My Cal 2 has no 'T' and works fine, I have the Mallossi pods on mine and Uni pod foam in them.Both, my LM3 and Cal2 had the same airbox that I took off, all you do is reroute the venting to the frame and it's fine.I can take a pic of the Cali and show you, if you want.
Hate to have you do all this work just to discover that the timing is already spot on. Ditch the points and do a Dyna-III ignition. Nothing to wear and hence no reason the timing should ever change once set.
