Author Topic: V7/V7 II Corbin Seat - start of a review...  (Read 25097 times)
Offline vhntr1
Re: V7/V7 II Corbin Seat - start of a review...
« Reply #30 on: August 08, 2018, 06:14:22 PM »
I also just received a Corbin for my Stelvio fits like a glove,much improved for the 10 hour days in the saddle.
« Reply #31 on: August 08, 2018, 06:37:13 PM »
Just so you know, folks, Corbin seat owners are my #2 customer.  They don't like lots of rain.  Just sayin.............. ......
If you care use code FREESHIP.
KoF
Offline Kev m
« Reply #32 on: August 08, 2018, 08:11:53 PM »
Different seat pan/different frame, kinda irrelevant to the V7.
Like I said, I've had ones that fit perfectly...
« Reply #33 on: August 08, 2018, 08:49:38 PM »
KoF
Nice to know.  My V7 Carbon came with a rain cover tucked under the seat.  Do you have a website?
Offline Kev m
« Reply #34 on: August 09, 2018, 05:35:56 AM »
http://www.kingoffleece.com/
I mean, like you could have seen that one coming...  :grin:
« Reply #35 on: August 09, 2018, 02:41:22 PM »
Thank you Kev.
Offline Kev m
« Reply #36 on: August 18, 2018, 09:28:10 AM »
Ok MMRanch proved to me the pin would probably not strip if I removed it and tried to shim it:
https://r.tapatalk.com/shareLink?url=http%3A%2F%2Fwww%2Ewildguzzi%2Ecom%2Fforum%2Findex%2Ephp%3Ftopic%3D97547%2E0&share_tid=97547&share_fid=72741&share_type=t
So inspired by that I backed it out (needed to use vice grips, none of my wrenches had a steep enough angle to clear the bottom or sides of the pan when on the post flange).
I backed it out one turn at a time until it latched, measured post height, and removed it to shim it.
There is 15mm of thread on the post, but I had to shim it ~7.5mm deeper to latch.
I Dremel'd the underside of the pin catch surface to extend it maybe another mm or so and reassembled with a small stack of washers.
I'm glad it latches. I just hope it's not too weak and doesn't snap the bolt or damage the base.
I still suspect most of the force on the seat with be vertical and not a lateral sheer force anyway. Will report back if any troubles.
« Last Edit: August 18, 2018, 09:39:45 AM by Kev m »
Offline egschade
« Reply #37 on: August 19, 2018, 07:55:27 PM »
Kev - if you encounter a lateral sheer force sufficient to pull the stud from the seat pan I suspect a damaged seat will be the least of your worries!
The elder Eric in NJ
2016 V7 Stornello #394
Past Guzzis:
2018 V7 III Carbon Dark
1985 LeMans 1000
2020 V85TT Adventure
V65 SP
V7 III Stone
V50
Breva 1100
EV Touring
Offline lomax
« Reply #38 on: March 04, 2024, 02:20:31 PM »
I wish Corbin made a seat for the 2023 V7 850.
64 R50/2, 01 DRZ400E, 23 Triumph Speed Twin, 81 Moto Guzzi CX100, 21 Africa Twin, 22 Janus Halcyon, 81 CBX, 80 GB500, 73 RD350, 1944 Nimbus type C, 14 Moto Guzzi V7 Racer, 73 Norton Commando.
Online Matteo
« Reply #39 on: March 04, 2024, 03:23:59 PM »
I moved the seat lock from under the mounting plate to the top. Seat latches snugly. All day comfy. Riding this one the most now.
free image hosting
« Last Edit: March 05, 2024, 12:52:29 AM by Matteo »
Offline Kev m
« Reply #40 on: March 04, 2024, 03:57:54 PM »
free image hosting
Nice!
I wonder if that would work on my Carbon as I still can't get the seat to latch on that one. I'll have to poke around.
Offline lomax
« Reply #41 on: March 04, 2024, 06:28:11 PM »
Anyone around Denver that I could try their seat for fit ?
