Author Topic: V 50 III trouble shooting  (Read 2933 times)
Offline Pakirk53
« on: August 06, 2018, 07:31:38 PM »
83 V 50 III had carbs gone through cleaned and sealed tank myself mechanic just went through carbs again and adjusted points but same symptoms. runs fine for 6 or less miles then acts likes it starving for gas stall and won't start again until it sits awhile and will run fine awhile then stall again
Online lucian
Re: V 50 III trouble shooting
« Reply #1 on: August 06, 2018, 07:39:29 PM »
could be loosing spark on one side , when it dies pull both plugs, if they're wet it's not fuel. ground them on the heads and crank it over, checking for spark sounds like a bad coil.
« Last Edit: August 06, 2018, 07:42:11 PM by lucian »
Offline not-fishing
« Reply #2 on: August 06, 2018, 07:55:58 PM »
My son and I resurrected a V50 III a year ago.  The first thing we did was a Dyna ignition, Dyna Coils and new spark plug wires.
Also after rebuilding the carbs, clean & reseal the tank we cleaned the petcocks.
Mark
Griso 1100
Rosso Corsa Lemans
1/2 a V50 III (with my son)
Online Chuck in Indiana
« Reply #3 on: August 06, 2018, 08:02:24 PM »
Check and make sure the fuel cap is venting.
Welcome to WG, BTW..
« Last Edit: August 06, 2018, 08:03:04 PM by Chuck in Indiana »
Offline Guzzi relic
« Reply #4 on: August 06, 2018, 08:03:22 PM »
Tank venting is a possibility. If you can open the cap just as the problem starts to happen and see if this helps. I've had caps that the vent was plugged or not working.
Also, I've had a few points/condenser ignitions over the years that did exactly this due to a failing condenser. After a few minutes of cool down they would start and run for a while again. Eventually it fails totally and you have no spark. Then its much easier to diagnose.
Ken
EDIT- I guess Chuck and I were typing at the same time...
« Last Edit: August 06, 2018, 08:04:16 PM by Guzzi relic »
I wonder where this goes?
Offline pehayes
« Reply #5 on: August 06, 2018, 08:06:22 PM »
PLUS ONE.  Loosen the fuel cap and drive around for awhile to see if it repeats.  A vacuum in the tank will prevent fuel from draining to the carbs.  Inspect all fuel lines for internal collapse.  Unscrew the filters from the side of each carb.  Turn on the fuel and watch.  Drain the fuel into a suitable can.  I should drain freely and continuously until the tank is empty.
Inspect the fuel filters at the side of the carbs.
Inspect the fuel filters residing on the inside top of the petcocks.
Offline Idontwantapickle
« Reply #6 on: August 06, 2018, 08:07:27 PM »
Probably is, clean out the petcocks, lines and screens but don't forget the gas cap either. My LeMans did this because of clogged tank vent in the cap. Not saying it can't be the ignition but your instinct is probably right.
Hunter
Edit. I must be the slowest typist here!
« Last Edit: August 06, 2018, 08:08:50 PM by Idontwantapickle »
Sir James Paul McCartney
AMA Charter Life Member
72 Eldo
84 BMW R100RS
Offline Diploman
« Reply #7 on: August 06, 2018, 09:37:06 PM »
As others have suggested, your problem may be insufficient fuel flow from the tank.  That said, historically, the most frequent and severe problem with the V50III has been the points ignition, a cobbled-up affair retrogressing from the problem-free Bosch electronic ignition fitted to the V50 and V50II.  Cost-Cutting, undoubtedly.
The solution is to fit an electronic ignition.  In the US, the most frequent choice for this conversion has been the Dyna ignition, as suggested above.  Even if your problem turns out to be insufficient fuel tank venting, sooner or later (probably sooner) you will want to fit an electronic ignition to your bike.  The points ignition is simply too unstable and problematic for the long term.
2015 KTM 390 Duke
Offline wrbix
« Reply #8 on: August 06, 2018, 09:46:40 PM »
Failing coils
Bill in VA, sometimes FL
"Eschew aphorism"
LeMans IV - "Giulia"
Lario - "Giulietta"
V50III cafe'd - "Leggera"
‘77 Convert - “Sofia”
Classic Mini
‘60 Austin Healey Sprite
Caterham Super Seven Sprint
‘13 Audi TTRS
Grumman AA5B (sold)
Offline Diploman
2015 KTM 390 Duke
Offline MMRanch
  • MMRanch
« Reply #10 on: August 07, 2018, 12:06:59 AM »
I have been know to remove the fuel cap and shoot a shot from an air compressor up the fuel line to clean off the crud that stops-up the petcock filter material.
Or ya could just take the petcock off and clean it right  ???  :huh:
I'll have to admit : my carbed bike has a special place in my life !  :azn:
« Last Edit: August 07, 2018, 12:09:14 AM by MMRanch »
2016 V7-II Stone
Offline Pakirk53
« Reply #11 on: August 07, 2018, 02:01:22 PM »
Thanks for all suggestions it gives me some guidelines to pursue
