The front is good . The rear needs a bit more cold pressure . Low pressure creates heat because the tire is squirming about creating friction which causes heat . Dusty
Have a Michelin Pilot 4 on the front and a new Pilot 5 on the rear. Inflated BOTH to 39 lbs before going on a 200 mile ride Saturday. Upon returning I found the Front hot up 3 lbs to 42 lbs... up from 39 Should I raise it to 40-41 lbs cold? Rear hot up 5 lbs to 44 lbs... more than 10% Should I lower it to ~37 lbs cold? Does that sound right?
39lb on a 1200 Sport? I am not sure what the book says but that seems a little on the high side. Typically 35 front and 38 rear (cold) for most sport radials. I have no idea what your books says.
Thanks, and here I thought higher pressure might cause heat but I guess not.
Can't go by "the book" Each tire brand needs to be checked with the 10%. Different structures, materials, and different brands are not exactly the same sizes, despite what the sidewall says. Riding style, weight, also factor in.
The sidewall pressure is not a recommendation.
I need to try this out. My Norge came with Perilli Angel GTs. The Owner's manual calls for 41 rear and 39 front regardless of load. Now since that model tire is what the bike came from the factory with I am to suppose the recommended pressure is for that tire on that bike. Will see if the 10% works with it. GliderJohn
