80 mph in first gear...???
I don't exactly remember , but I've owned two R100'S with the highest final drive ratio available , at redline in first gear it was running maybe 60 MPH . If you were employing the highest optional 1st gear ratio , and could rev to 8000 RPM's you might see an indicated 75 MPH , which equals about 67 MPH corrected . Dusty
Look up ratio of the stronger 4 speed gear box.. It's what he used in his race bike..
Who cares?!
..... Best thing you can do for R-90 /100 is to lighten the flywheel. They shift ten times better. Way less clunks in shifting.
Well, to answer your question.Dusty and Huzo..
Since there seems to be a fair number of BMW Airhead fans here, I thought I'd share....A good friend of mind offered to sell me his R90S if I gave him right of first refusal. So, I brought this beauty home today!IMG_3467.JPG by jay_snyder67, on FlickrIMG_3469.JPG by jay_snyder67, on FlickrIMG_3466.JPG by jay_snyder67, on Flickr
That�s what happens when I peruse WG after drinking sever craft beers! At least I wasn�t on eBay...
Oop's
Is that Reggo's bike? Ouch!
BMW lightened the fywheel starting in 1981.I had 1994 R100R Mystic, and 1992 R100R. They definitely shifted more smoothly, but, the earlier bikes with the heavier flywheel aren't as bad you may think. Preload the shifter before pulling in the clutch, and you are rewarded with a smooth shift.The R100R was the most refined of the airheads, with paralever rear suspension, Showa fork from the K75, and Brembo four piston calipers, single disc in 1992, and dual 1993-1995. The brakes were great, even the single disc '92 was very good, and suspension very good as well.
My first bike was a newly purchased 1976 Silver Smoke R90S. After I crashed it, I bought a new 1978 R100S and it was equally awesome. The 3/4 seat was cool.
The Slash-Sixes were the pinnacle of Airhead models. There were flaws (remote front brake master cylinder, flexible triple clamps, weak flywheel bolts on �74s, and soft valve seats), but the overall execution is sublime. No plastic turn signals as in later models, but aluminum. The five speed transmission was long overdue and the disc brakes, too. The engine redesign placed the pushrod tubes out of sight and the 900 variant added 12-17 additional horsepower to the party over the R75/5. The Dellorto Slide/needle carburetors, gold or gray fade paint, and the Cockpit fairing of the R90S just took the design to a brilliant level. I believe that the release of this bike heralded the end of BMW�s post-WW2 designs. The days of practical people movers had ended. BMW had returned to the engineering magic that they had displayed in the late twenties and thirties, when they had dabbled in overhead valve heads, supercharging, full suspension, monocoque frames, and even Art-Deco bodywork. This trend continues even now, much to the despair of the Luddite lovers of the simpler designs. And though the newer bikes incorporate features that some of us old guys consider redundant, BMW has remained a leader in motorcycle innovations. The R90S is more than just a great looking bike...
Pretty bikes, F-22. You do nice work. The push-rod tubes weren't moved to the bottom for aesthetic reasons. There was actually a very good reason: crankshaft and cam traded positions which resulted in cylinders higher on the engine providing more cornering clearance. It was a smart move.True, the lower fairing/turn signal mounts require a bunch of work to remove, but normally that's not a necessary job. And removing the fairing is a bit like one of those Chinese puzzles - once you know the tricks it's pretty simple. Another point about the disc brakes. True, Guzzi did a better job on the brakes than BMW, but both made the mistake of using master cylinders that were too large. The BMW brakes, even those ATE swinging calipers work well with 14 or 13mm master rather than the 16 or 17mm they came with. On the other hand, the Guzzi discs are iron , including the carriers (added unsprung weight), while the BMW used aluminum carriers. By the way, my dad was Czech - lived there till he was 16 before moving to the USA. Sometime I'll have to visit.
