Author Topic: Why did Larios drop valves ?  (Read 20578 times)
Offline jacksonracingcomau
Re: Why did Larios drop valves ?
« Reply #60 on: November 24, 2018, 04:15:52 PM »
Brian
I spent a long time measuring and checking before putting mine together, the important part is not which brand springs you use it is setting them at correct height / pressure.
Avoiding coil bind, of course
I also had to grind rockers for clearance and shorten pushrods to fit elephant feet adjusters
new oe. alves are fine imho
infact mine is all std except valve springs and adjusters
just a bit of love in assembly
this one is a hooter, thrashing it mercilessly every day.  no rev limiter on std points ignition
i lit the fuse, any bets on result?
will prob see 10k miles over summer, all on the noise
Then the hot one goes in
« Reply #61 on: November 24, 2018, 07:10:40 PM »
Brian
I *love* the character of the Lario engine. That rush to redline is addictive.  :thumb:
Attaboy, Martin.. hopefully you have it finally sorted.
Offline IceBlue
  • Where words fail, music speaks. H. C. Andersen
    • Moto Guzzi Lario Fan Site
« Reply #62 on: November 25, 2018, 12:44:42 AM »
Brian
You may very well be right on all counts.
I'm taking the chance too on two piece standard valves, my list was more in the direction of making it as bullet proof as possible - here I believe one piece valves are safer.
As to the spring, here again you may be right, however, Guzzi's own progressive SB springs has served me VERY well. Also recommende by Guzzi for the 2V heads - the 2V valve train use the same cam shaft as the PT and PX mills, same stems width on the valves etc. Best of all, I haven't seen any cam lobe wear after 18.000 km. So far it's still my choice for the Lario valve train mod., but time will show. As I said the jury is not in yet.
I have hit 9000rpm by accident on mine, but I heard valve float - not healthy, and with the spring I use, it sets in at red line.
Yes Chuck - the takeoff :whip2: to red line is addictive  :drool:
Lots of SB's to choose from, but I almost always end up on the Lario.
Ciao
Copenhagen Denmark - http://www.facebook.com/motoguzzilario
V65 Lario - Short legged total brat
V65 Lario - Silver Fox
V75C
V75/4 fastest 4V!
« Reply #63 on: November 25, 2018, 03:04:42 AM »
Ciao
from my experience measuring 3 motors the installed height is crucial to measure
you may only have one valve bouncing
heads I had that were supposedly fixed varied hugely, pot luck if springs alone are enough
good that cam still measures true, my check is just measure lift at pushrod , no need to take apart until wear shows on dial gauge
only bad thing mine does is tingle at bars will balance crank on next, bbut not a biggie
btw new oe ex valves are ss
inlet still 2 piece but no concern imho
