Author Topic: 04 Ti with carbs  (Read 2661 times)
Offline ratguzzi
    • road kill
04 Ti with carbs
« on: September 01, 2018, 02:33:52 PM »
I have tried many a map on EVs, Stones, etc and very hard to get over 42 mpg. Got tired of it so like my EV powered loop, I put on 36mm pumpers on the Ti.
MG Cycle sells all you need, manifolds, cables, starter switch, etc. Runs perfect and if it's anything like the EV motor, I will be seeing over 50mpg constantly.
Main problem is the later Tontis have an extra piece of frame that bolts to the top of the trans and I had to cut off the left side so the air filter would fit.
JB
John Boettcher
Wonder Lake, IL
"I'll quit riding when they pry the handgrips out of my cold dead fingers"
Offline bigbikerrick
Re: 04 Ti with carbs
« Reply #1 on: September 01, 2018, 02:45:42 PM »
Hey John, thats a cool conversion! Does it run any better/faster with the carbs?
I am currently trying to sort a running issue with the fuel injection /TPS on my 03 aluminum, so this is very interesting to me. Looking forward to your reports coming up. :popcorn: :popcorn:
Rick
Offline yogidozer
« Reply #2 on: September 01, 2018, 02:52:31 PM »
always wanted to try that! what are you using for an ignition?
Offline ratguzzi
    • road kill
« Reply #3 on: September 01, 2018, 03:00:08 PM »
Hard to tell on the performance. Runs good and crisp straight out of the box. I had to sync the cables and play with the idles screws but runs smooth as silk.
I used the stock ignition and ECU, just unplugged all the injection stuff. New switch is obvious and easy to wire in.
See the T3 floor boards, tank and seat?
JB
John Boettcher
Wonder Lake, IL
Offline balvenie
« Reply #4 on: September 01, 2018, 07:57:20 PM »
Well :embarrassed: :shocked: I was under the impression that it couldn't be done or I would have done it years ago.
onya John :grin: :thumb:
Oz
04 Cali
Offline Gliderjohn
« Reply #5 on: September 01, 2018, 08:23:39 PM »
Have them on my T-3 and couldn't be happier.
Back in central KS
Offline ratguzzi
    • road kill
« Reply #6 on: September 01, 2018, 08:24:28 PM »
Depends what year you are doing.
JB
John Boettcher
Wonder Lake, IL
Offline balvenie
« Reply #7 on: September 01, 2018, 10:17:36 PM »
JB
Thanks John
Oz
04 Cali
