Author Topic: The Eagle has landed, Mk1 Le Mans content  (Read 14233 times)
Re: The Eagle has landed, Mk1 Le Mans content
« Reply #30 on: June 29, 2019, 08:43:11 AM »
Looks great.  I have the Ago’s on my CX and they are way more comfortable than the stock pegs IMO.  I will probably get another set when I put my LM I back together, though they are not cheap anymore.
I really do dislike the US headlight trim, does anyone know if the trim can just be replaced with the Euro trim or does it require a whole new light?
« Reply #31 on: June 29, 2019, 09:49:15 AM »
MG Cycle sells both the Agos and Tarozzi.   The Agos look like they only are a little more than an inch more rearward than stock.  The Tarozzi are more like 3 inches back, and an ice nah higher.
I’ll likely go with Tarozzi.
« Reply #32 on: June 29, 2019, 09:52:03 AM »
Requires a whole new headlight. On Ted's Le Mans, I used one from a V65C which is identical to the original Euro unit other than it's chrome (I had it powdercoated black).
Offline Turin
« Reply #33 on: June 29, 2019, 10:35:35 AM »
I've got tarozzi rearsets on both my 850T and my LeMans SE. They are comfortable, and replacement parts are readily available.
1985 Sidlow Guzzi
« Reply #34 on: June 29, 2019, 10:49:58 AM »
Charlie, thanks.  Now I just need to source  a V65C headlight.
« Reply #35 on: June 29, 2019, 12:34:07 PM »
Or a V50 III which would already be black. That's what I bought from Ed Milich, but when it showed up it was a chrome one from a V65C.  :wink:
« Reply #36 on: June 29, 2019, 03:21:23 PM »
 Charlie,  thanks, I’ll have to send Ed an email.
« Reply #37 on: June 29, 2019, 03:34:08 PM »
Agree.  Looks much better when the headlight is flush with the fairing.
Offline s1120
« Reply #39 on: June 29, 2019, 06:55:35 PM »
You know... maybe just because its what I am used to always seeing.... I like the extended headlamp..
Paul B
« Reply #41 on: June 29, 2019, 10:40:18 PM »
Hmmm, I think that I’ll be looking for a V50 III headlight.
Offline Stevex
« Reply #42 on: June 30, 2019, 12:55:46 PM »
Last weekend, I finally got the Le Mans back together after pulling the forks for rebuild/upgrade.
The above pics are from the first ride after fork rebuild with '96 Honda VFR750 cartridges. The new forks work brilliantly!
Just need to get the fairing back on it (couldn't wait to try out, and skipped the fairing).
Did the same mod on my LM2 last winter but am yet to test ride the finished article.
As a matter of interest, what viscosity fork oil did you use and what air gap?
Also, the original LM had longer single fork springs than the MK2s two springs per fork set up; I had to ditch the shorter of my springs due to the length of the RC36 cartridges. How did you get around that problem?
« Last Edit: June 30, 2019, 01:00:57 PM by Stevex »
« Reply #43 on: June 30, 2019, 05:05:01 PM »
I'm not sure of the air gap, but, it was 235cc of 10wt per leg.
I'm pretty sure that my friend who did the work just shortened the springs, as I brought home some short spring pieces.
Offline Stevex
« Reply #44 on: July 01, 2019, 12:08:24 PM »
Thanks for the reply.
As a matter of interest, what made you decide on 235cc?
I went for the same air gap that Honda quoted for their donor forks.
« Reply #45 on: July 01, 2019, 06:02:41 PM »
235cc was arrived at by measuring the air gap, but, unfortunately, I can't remember what it got set to.
