Author Topic: 2 year 35k miles V9 Roamer Report  (Read 15562 times)
Offline bad Chad
Re: 2 year 35k miles V9 Roamer Report
« Reply #30 on: August 27, 2023, 05:46:32 PM »
Just goes to show, it's all very personal.  i have a 17 Roamer.  I love the power delivery, it's close to perfect, if it made 20 more Ft pounds of Torque it would be perfect!   I found the suspension lacking.  I put on better shocks and up graded the forks and now I find it much better, and quite good now for the type of bike it is.  Others are happy with stock, and thats good for them, they didn't have to spends hundreds of dollars to get things where they wanted!  It really is a fun bike, you hear this kind of blather all the time, but this bike really is more than the some of it's parts.
2016 CSC 250TT Zongshen
Online faffi
« Reply #31 on: August 28, 2023, 01:08:53 AM »
I agree that the stock suspension is not very good. However, damping and spring rates appear to be correct, because - at least on mine - tires wear with zero cupping. It is just that the items are too crude to give a comfortable ride over sharp bumps, because compression damping is then too firm. Cartridge inserts in the fork, or emulators, plus more sophisticated shock absorbers will improve things, but I find that I can live with mine stock for now.
BTW, I am curious to learn what shocks you went with and also what modifications you made to the fork.
Current bikes:
2018 V9 Roamer
1982 XV750/1100 mongrel
1990 XT600Z
2001 NT650V in bits
Offline bad Chad
« Reply #32 on: August 28, 2023, 03:04:13 PM »
I got a set of Ikon Dial a Ride shocks from MG cycle.   They are far from the most sophisticated or costly shocks, but they are a great improvement over stock.  Much more adjustability, and far more compliant over bad road.   The forks, I sent off to RaceTec in California after I talked with them on the phone and discused what I was looking for.   I told them I was looking for better overall performance for street riding, and for around $300 they sent the back much better than what I sent them.
Offline Zenermaniac
« Reply #33 on: August 28, 2023, 03:14:00 PM »
I used lighter fork oil and increased the air gap on my forks and it’s much better. I found a preload sitting on the rear shocks where it’s tolerable for now until I   feel like shelling out the bucks to upgrade. I found my handlebars felt better (less shake on bumps) after removing the chrome end weights. To cover up the holes I found some plastic 6mm license plate bolt reflectors that were just the right size and very light weight. Overall, I’m happy with my Roamer. I wish that MG would make a smaller 400 v-twin, too. My Roamer needs a little brother.
Online faffi
« Reply #34 on: August 28, 2023, 03:33:24 PM »
Thank you. I have used Koni / Ikon shocks on several bikes. For my KZ650, I had a set specially made from them that was 21 mm longer than stock with the same amount of extra shock travel, plus a spring made for my bodyweight since I ride solo always. I wanted the extra length to gain some vital cornering clearance, but I have grown older and now I want to keep the stock, limited clearance of the Roamer in order not to be tempted to that old foolishness of fast cornering again - I've had more than enough heavy injuries.
Current bikes:
2018 V9 Roamer
1990 XT600Z
2001 NT650V in bits
Offline swix76
« Reply #35 on: September 24, 2023, 11:32:19 AM »
I've been thinking about switch from my v7 III to the v9 roamer (instead of the new v7 850).   IMO, the Roamer is just a cooler nicer machine than the new v7 850 (like metal fenders, nicer paint, nicer hand controls switches) The roamers handle bars look like they'd provide excellent comfort and control; not too low, not too high with a nice sweep back. The peak torque is low in the rpm range but the torque from what i've seen/heard is pretty much flat though out the rev range.  A little more HP than the v7 III.  The weight is either lighter or just the same as the v7 III.  This is all appealing to me.  I am 5'5" and the v7 III has a comfortable riding position for me and I can't see why the v9 wouldn't fit me as well.  (The new v7 850 which I have test ridden, seems a little taller and heavier.)
I really like the orangey yellow color but i'd be fine with the white if it was the only one I could find.
I got my v7 III in 2020,  26k miles on the OD and trouble free.
Congrats on the 70k!
Offline bad Chad
« Reply #36 on: September 24, 2023, 12:45:14 PM »
Sounds like it would be a great bike for you, now your only issue will be finding one!
« Reply #37 on: September 24, 2023, 01:24:29 PM »
I count 4 Roamers on FB Marketplace.  All under 10k miles
2022 V85TT Guardia d'Onore
Offline swix76
« Reply #38 on: September 24, 2023, 08:00:04 PM »
Yup, all white.  Not one orange :(
Offline Zenermaniac
« Reply #39 on: September 25, 2023, 09:53:39 AM »
Mine is white. Gas fumes and droplets tend to stain it yellowish around the gas cap. Go for the orange.
Online faffi
« Reply #40 on: September 25, 2023, 12:25:37 PM »
I prefer the red, but ended up with a white because it was for sale.
Current bikes:
2018 V9 Roamer
1990 XT600Z
2001 NT650V in bits
Offline bad Chad
« Reply #41 on: September 25, 2023, 02:24:16 PM »
Guzzi calls it Giallo solare,  thus in english it's, Solar Yellow.
Online faffi
« Reply #42 on: September 26, 2023, 05:13:38 AM »
Did you just get white and orange in America, or did you also get the red one?
Current bikes:
2018 V9 Roamer
1990 XT600Z
2001 NT650V in bits
Offline chuck peterson
« Reply #43 on: September 26, 2023, 09:31:29 AM »
….”My Roamer needs a little brother…”
….2007 Nevada, seriously ridiculous for me to ride when i was weighing in at 230lbs, but perfect when I’m 185, 5’9”, gimpy 65 yr old knees
Previously generation to that was V65c…the ‘c’ is an important branch of the V65SP…V65 line. A bit of a California chopper attitude introduced w fatter rear tire, narrower taller front wheel and buckhorn pullback bars. Unusually comfortable upright chair like seating these sorta things, minus the buckhorn’s are still there on the Roamer
Previously generation being the original small block, a V35, V50 in the mid 70’s somewhere?
150k on Verts
750 Nevada
400f
R5 Yammie
BV250
« Reply #44 on: September 26, 2023, 09:35:14 AM »
Great write up by the way! Neat to see it revived after another 35k
I was, past tense, lusting for the white w red stripes version. I figured a medium size screen, decent saddlebags aaaaaaaaaannnnndddd dd…….
Your gone! Last seen crossing the Rockies…
150k on Verts
750 Nevada
400f
R5 Yammie
BV250
