Author Topic: Tonti frame clutch adjustment  (Read 4901 times)
Offline Thirtyaughtsix
« on: September 30, 2018, 05:58:43 AM »
So got a whole new throwout for my 850T, I followed Greg benders clutch adjustment guide for loop frames and I don't think I got it quite right. Is there anything different about the tonti frame? I can't fully disengage the clutch while also having any free play in the cable. Bike does have SD-tec clutch plates. What am I missing?
Also I do have a correct 850T clutch cable as far as I'm aware, I've read they're one of a kind
« Last Edit: September 30, 2018, 08:55:04 AM by Thirtyaughtsix »
2019 V7 III Stone " Murci "
1975 850T " Guzziaughtsix "
Offline jrt
Re: Tonti frame clutch adjustment
« Reply #1 on: September 30, 2018, 08:53:26 AM »
I think the SD plates are thicker than stock (did you happen to measure them?).    I am writing this off memory, so I could well be wrong- do a search here for SD plates and see what others have said about installing them.
L-720
1973 Eldorado
2003 Yardbird (1100 hydro)
2020 R1250RS
« Reply #2 on: September 30, 2018, 08:57:48 AM »
I have not, I was not the one who installed them so I've never actually laid eyes on them. I too have read they're a bit thicker. Outer body sits maybe a thousandth or 2 or 3 recessed with the all new everything in at the moment, FWIW
Offline acogoff
« Reply #3 on: September 30, 2018, 09:09:42 AM »
     What I would do is this, Start with .160 inch freeplay as eyeballed at the front of the handlebar clutch lever, By this I mean the crack at the front of the pivot point, not at the end of the lever itself. Then pull the clutch lever all the way in and hold it there somehow (clamp or a friend holding it) then go to the back of the transmission and see that the end of the arm there is not hitting something that is not letting it push the assembly in as far as it should. If that is happening , you need to lengthen forward the littlescrew on that arm. If the arm is not hitting anything and the clutch does not disengage, I am afraid you will need to pull the transmission and check out your clutch plates. Your center plate may be warped or broken comes to mind. Good Luck to you.
« Last Edit: September 30, 2018, 09:17:44 AM by acogoff »
Marshall County Minnesota USA
Offline lazlokovacs
« Reply #4 on: September 30, 2018, 09:50:08 AM »
I've experienced the exact same symptoms with clutches replaced by dealers, (when I've done clutch jobs myself I've had no problems whatsoever :wink:)
you can alleviate the problem by putting a ball bearing in between the throwout assembly and the pushrod, or an extra washer between bearing and outer body of throwout assembly. Has enabled me to stop my dealer fitted clutches from dragging when hot.
YMMV
Offline wirespokes
« Reply #5 on: September 30, 2018, 12:39:40 PM »
I replaced the clutch plates in the 87 LeMans within the last year with some new ones from Stein Dense. When I started it up first time, the clutch wouldn't disengage. I thought I'd done something wrong but couldn't find anything amiss. Finally I started it up in gear and test rode it. By the time I returned it was acting normally - they had worn just enough to have free play.
Online John A
« Reply #6 on: September 30, 2018, 03:06:57 PM »
If you have a bar clamp that is split you can make a spacer to position the lever farther from the bar so it can have more throw. there may be a Brembo spacer for this, a half moon sort of a thing. I made my own and it needs to fit accurately or it will break the clamp.
« Reply #7 on: October 01, 2018, 07:37:45 AM »
I sorta like the sound of this, but unless I get some pics or something I'm thinking I'd have a much easier time finding a ball bearing of appropriate size and throwing it in there
« Reply #8 on: October 01, 2018, 08:29:13 AM »
Any time I install the SD-TEC plates, I use this throw-out bearing:
http://www.mgcycle.com/index.php?main_page=product_info&cPath=193&products_id=4793
Here's an interesting new part out of Italy, a new version clutch outer body, or clutch push rod plunger using 2 sealing o-rings to help prevent leaks at this common leak location. This new version uses two of the 90706170 orings rather than the original one oring. The other difference is that the large diameter section of the body is 2.5mm longer than the original 14086100, and the overall length of the piece is 0.4mm longer. The additional length of the main body section would theoretically compensate for thicker clutch plates.
« Last Edit: October 01, 2018, 08:29:30 AM by Antietam Classic Cycle »
« Reply #9 on: October 01, 2018, 12:04:00 PM »
I like this even more. Do you use this alone? No additional ball bearings or washers anywhere?
« Reply #10 on: October 01, 2018, 12:26:59 PM »
Alone. Nothing needed except that.
« Reply #11 on: October 01, 2018, 01:20:12 PM »
I'll order now, I'll keep yall posted. Thank you
