Author Topic: Carb rebuild - 36 PHF tiny green o-ring?  (Read 2174 times)
Offline Cal3
« on: September 30, 2018, 07:33:32 PM »
Hey Guyz,
I am going thru my 36 PHF carbs. I bought rebuild kits and there is one tiny green oring in the kit, all others are the usual black orings. This is the smallest "o" in the kit. I have yet to find such a tiny green oring as I have disassembled and cleaned the carbs. Anybody know where that one goes??
Thanx,
Clay
Re: Carb rebuild - 36 PHF tiny green o-ring?
« Reply #1 on: September 30, 2018, 07:49:22 PM »
Without a better sense than "tiny", I'm gonna guess - with absolutely no education to the guess - that it goes around either a jet or the air screw shaft, probably in a groove. The color probably isn't significant.  A pic of the bits might help.
Online John A
« Reply #2 on: September 30, 2018, 07:59:17 PM »
Is there just the one and is there one in the kit for the other side? Usually the small o rings go on the mixture screw, as David said.
« Reply #3 on: September 30, 2018, 08:08:27 PM »
I've never used that tiny, green o-ring on any carb rebuild.
Offline Cal3
« Reply #4 on: September 30, 2018, 09:22:21 PM »
Charlie.....you are making me feel better.
Yeah guyz on your guesses/hints....those areas are where some of the small o's go. But those are all small black orings in the kit, the green one is even smaller.
« Reply #5 on: September 30, 2018, 09:42:37 PM »
Another small one goes on the choke jet(plugs into float bowl), then there is another on the accelerator jet.
« Reply #6 on: September 30, 2018, 09:51:48 PM »
I did say I was guessing. :angel:
« Reply #7 on: September 30, 2018, 10:36:59 PM »
Both black.
