Author Topic: Rear drive leak - laid it flat on its back while pulling the gearbox  (Read 3111 times)
Offline earemike
  • Lurker
Hi all,
Feeling a little stupid - laid the rear drive on the bench wheel side down & she’s leaked. It hasn’t dropped a heap of oil but enough. Never had that happen before,
My question is which seal is most likely the culprit - wasn’t leaking on the bike so I’m hoping it’s the outer seal...
Thought I’d post here as you blokes have seen it all, anyone out there wish to make an educated guess?
Cheers,
Mike
850 T3
850 LeMans
SP1000 Stucchi
V11 Ballabio
Re: Rear drive leak - laid it flat on its back while pulling the gearbox
« Reply #1 on: October 04, 2018, 05:41:20 AM »
Which bike? There are a lot your sig line. The only one you'd need to worry about is the V11. Allthe others breathe through their pinion bearings and if you leave them on their side they'll leak.
Offline earemike
  • Lurker
« Reply #2 on: October 04, 2018, 07:42:35 AM »
Thanks Pete,
Now I’m feeling more stupid - my rough as guts LM2
Appreciate the guidance, when I get her together I’ll do fresh fluids and monitor.
Can’t understate how helpful your comment is.
Best,
Mike
850 T3
850 LeMans
SP1000 Stucchi
V11 Ballabio
Offline KiwiKev
« Reply #3 on: October 05, 2018, 12:16:18 AM »
Pete,
I have the rear end out of my Cali 1100i (1998) - still. I was cleaning it up the other day and some oil leaked out of the gearbox end.
Does that indicate the seal needs replacing ??
Kevin
« Last Edit: October 05, 2018, 12:20:42 AM by KiwiKev »
Offline earemike
  • Lurker
« Reply #4 on: October 05, 2018, 12:26:08 AM »
Pete,
Kevin
Hoping he’ll say it’s the same rear drive as it’s not a spine frame  :grin:
Otherwise I ain’t been listening properly...
850 T3
850 LeMans
SP1000 Stucchi
V11 Ballabio
Offline KiwiKev
« Reply #5 on: October 05, 2018, 12:37:59 AM »
Mike, sorry I thought your oil was leaking down at the inside - wheel end?
Mine is running out the tube - gearbox end.
Kev
Offline earemike
  • Lurker
« Reply #6 on: October 05, 2018, 03:59:48 AM »
Kev
Yes Kev!
Pete straightened me out - laying it flat oil dribbled out the front & went in various directions. When I thought about it I’ve never normally put the drive on the bench like that before (but it’s been 5 or so years since I did it swapping a uni).
Regardless good luck! (I often assume what I shouldn’t, makes me a bit of a mouth breather at times)
850 T3
850 LeMans
SP1000 Stucchi
V11 Ballabio
« Reply #7 on: October 05, 2018, 09:24:55 AM »
The rear drive is not sealed on the ones with the enclosed driveshaft, Cal series so it's completely normal for the oil to run out the driveshaft end. It's just going past a pair of tapered roller bearings that the pinion rides in.
Offline KiwiKev
« Reply #8 on: October 06, 2018, 07:08:39 PM »
Thanks John
