Author Topic: Eldo fork rebuild - shims  (Read 1668 times)
Offline BSABEN
« on: October 06, 2018, 09:43:53 AM »
I am rebuilding my drum brake Eldo forks. There are shims above the upper slider bushings. I can't figure out what measurement these shims are intended to equal. I assume they are to even the overall length but what is to be measured?
I want to have this shimmed correctly but i have no idea what to measure / shim for!
Re: Eldo fork rebuild - shims
« Reply #1 on: October 06, 2018, 10:04:33 AM »
I think that is shimmed to keep travel of the bush to a minimum when tube goes through, less wear.
