Author Topic: What size socket needed  (Read 2400 times)
Offline Ncdan
« on: October 15, 2018, 07:45:32 AM »
Hey guys, a while back Pete made us aware of the dry swingarm bearing issue with the 1400 models. It takes a special tool to remove the nut holding the swingarm which can be made from a socket. What size socket was that? When I change the rear tire feel the need to check the bearings as Pete recommended.
Re: What size socket needed
« Reply #1 on: October 15, 2018, 11:42:02 AM »
If it's anything like the earlier CARC bikes it's not very tight but has a couple of pinch bolts.
Offline Ncdan
« Reply #2 on: October 15, 2018, 11:47:02 AM »
I think this is different Roy. It's a specialized socket which can be made from a standard socket. I just can't remember what size
Offline kballowe
  • - Kevin the Great -
« Reply #3 on: October 15, 2018, 12:32:53 PM »
Subscribed.
I'm getting ready to do the same thing.
Offline lucian
« Reply #4 on: October 15, 2018, 01:06:11 PM »
I made mine with a spare 30mm socket. I can loan it to you when you need it. There are pinch bolts as well.
« Reply #5 on: October 15, 2018, 01:19:58 PM »
It looks very similar to me. I just used a pair of pliers on mine but a socket is nicer.
Moto
« Reply #6 on: October 15, 2018, 01:28:24 PM »
There is a special tool available for the CARC bikes, not necessarily fitting the 1400:
http://www.guzzitech.com/store/product/cnc-carc-tool/
The same source shows another castle nut tool. The first one works as advertised.
« Last Edit: October 15, 2018, 06:00:06 PM by Moto »
Offline lucian
« Reply #7 on: October 15, 2018, 01:30:32 PM »
Pinch bolts and pre load bushing are only torqued to 10 NM, so any c spanner would work. Swing arm pivot is tightened to 60 NM. The castellated socket does make it easier to torque to spec, however I think pre loading these bearings by feel is an acceptable  way to go.
Offline Ncdan
« Reply #8 on: October 15, 2018, 09:13:20 PM »
Thanks a bunch guys and thanks Lucian for the offer to use yours.
