Author Topic: Building a Benelli 650 Tornado  (Read 150378 times)
Re: Building a Benelli 650 Tornado
« Reply #90 on: January 02, 2019, 07:49:40 PM »
Very cool that you cast the fuse box lid yourself! I think a quick and dirty vacuum pot could be made of a strong paint bucket and a ejector style air fitting. It will obviously not be able to pull down to -0.9 bar or something like that. But I think it would be possible to pull the airbubbles out with less. Might be worth a try. A piece of pipe with ends closed could also be used.
To make a vacuum bottle can I just put the resin filled mold into a sealed container with a spigot attached to a shop vacuum and run the shop vac? I would like to get better results with the clear lids, need to make a couple more for my Moto Morini fuse panel lids.
PS - yes to the fluids, just oil and fork oil, the Italian "Made In Italy' decals came in the mail today along with new points, condensers and the correct front axle nut to finish it all off. I am showing the Benelli and the Moto Morini 500 in the vintage display at this years International Motorcycle Show when it rolls into town a week from this coming Friday.
Jim
« Reply #91 on: January 04, 2019, 08:09:55 PM »
The original signal lamp lens screws were either missing or the Philips heads were mostly rounded out as a result of corroded screws and aluminum signal light bodies. Thee CEV signal lights take a 3.5mm screw, fine thread, NOT AN EASY THING TO FIND!
Aermaccchi / Harley Davidson used the same signal lights for a brief period and searching the Aermacchi / HD Ebay pages turned up a NOS packet of screws, 8 came in this little packet, just the right amount needed.
Repro MADE IN ITALY decals arrived, I made a measurement of the original decal placement before I had the tank repainted, 22 cm from the back folded lip to the base of the decal
I am a sucker for little details like this, IMHO they 'make' the bike. they cost so little in the great scheme of things but I always notice a corroded fastener or a missing decal on otherwise very nice restorations.
« Last Edit: January 01, 2020, 10:07:19 PM by canuck750 »
Offline Rick4003
« Reply #92 on: January 05, 2019, 07:37:42 AM »
Jim
I definitely think that it is worth a shot. Any vacuum must be better than no vacuum, I would believe that it would take a bit longer to pull out all air bubbles from the mix with a weaker vacuum, but never the less it should help extracting the air. How long is the working time on the resin after mixing?
I saw a video on youtube where they are casting a replacement headlight glass for an old 1936 Cadillac and the vacuum pot they are using looks like nothing more than a piece of thick walled pvc pipe (edit: it's a steel pipe) with a thick piece of acrylic on top and sealed by rubber gaskets. I'll try and see if I can find a link. It looks like a doable setup in the home shop.
Found it: https://www.youtube.com/watch?v=QMe9MOBjkmc
It goes through all the steps of making the casting, but it is the vacuum pot I thought was interesting.
-Ulrik
« Last Edit: January 05, 2019, 07:39:12 AM by Rick4003 »
Moto Guzzi Ambassador - 1967
Yamaha FZR 600 - 1996 - SOLD
« Reply #93 on: January 05, 2019, 03:26:30 PM »
-Ulrik
Thanks Rick!  The resin set-up time is well over an hour, very slow reaction. I am going to rig something up along the lines of your suggestion, hopefully the casting results will be much better.
Offline SED
« Reply #94 on: January 05, 2019, 09:39:34 PM »
Beautiful work - again!  Have fun at the show.
1983 LeMans III
1981 Monza
1947 Ariel Red Hunter
1939 Ariel Red Hunter
1937 Guzzi GTV
Offline Rick4003
« Reply #95 on: January 10, 2019, 09:49:21 AM »
Hi Jim,
Just to follow up on the diy vacuum pot, I just found a video of a guy making one with an old fridge compressor and a kitchen pot. He is able to pull - 0.9 Bar vacuum so it obviously works very well! Just another idea on how to make one.
Here's a link
https://youtu.be/BeiW_37rS-U
-Ulrik
« Reply #96 on: January 10, 2019, 08:16:44 PM »
Hi Jim,
Here's a link
-Ulrik
Thanks !!
I am going to make one!
« Reply #97 on: January 18, 2019, 09:47:25 AM »
Last weekend the International Motorcycle Show came through Edmonton as part of the North American tour. I organized the local vintage motorcycle show as part of the Canadian Vintage Motorcycle Group - NORAL section. We had space for twenty motorcycles and a wide cross section of years and makes was shown.
I was very happy to show two bikes I finished last year, the Moto-Morini 500 and the Benelli 650. Both got a lot of attention but for interest the Benelli was the winner of the two. Many people asked about the Benelli, very few knew anything about it and I did not meet one person who had ever seen one.
« Last Edit: January 02, 2020, 02:07:12 PM by canuck750 »
Offline Rick4003
« Reply #98 on: January 19, 2019, 09:34:55 AM »
Great looking bikes both of them. And I have to agree with the  crowd at the show. I had heard about and seen the Moto Morini before, and while having heard and known about Benelli bikes I had never seen the 650 model you have. In any case it is a great looking bike after you have had your hands on it. Thinking of how it looked when you picked it up it has been quite a transformation.
Offline Bucky
« Reply #99 on: January 20, 2019, 05:59:55 AM »
Another fabulous resurrection....out standing!
1973 Eldorado
« Reply #100 on: January 31, 2021, 10:14:25 AM »
Jim
My friend who makes resin jewelry places her molds on top of her running clothes dryer to vibrate out the bubbles
« Reply #101 on: January 31, 2021, 10:41:04 AM »
That is a great idea!!  I love simple solutions like that, going to give that a go. Thanks
« Reply #102 on: February 02, 2021, 07:55:35 AM »
She says "Its a nice warm spot and it seems to work better if the dryer is empty"
(I guess the weight of wet clothes in the dryer dampens the high frequency vibrations)
Good luck!
