Author Topic: Cheap 78 LM I on Craigslist  (Read 9094 times)
Online blackcat
Re: Cheap 78 LM I on Craigslist
« Reply #30 on: October 22, 2018, 10:46:04 AM »
blackcat - You could have them nikasil plated to the dimensions of your pistons.
I guess my estimation of the bike, and LM series 1, was off a bit. I had no idea they were worth that much.
That is what I'm thinking of doing with the barells.
Compared to a 76 Ducati 750 SS, the same year Guzzi Lemans is comparatively cheap.
« Reply #31 on: October 22, 2018, 10:53:59 AM »
I got this "box" of Lemans for $3,500, which included nos switches,vapor blasting of engine,etc., a nos seat, barells machined and one over pistons,rings and some other stuff that I can't remember right now.
Now I'm here:
I haven't started on the engine or transmission but everything has been vapor blasted clean except for the carbs which have to be done too.  Little by little it will get done, but with work this may take awhile.
One problem is the barell, it's been (both) bored but due to a loose pin it was scored at the bottom of the skirt. In the end I will probably send it out and have it fixed instead of putting it together and seeing what the compression says, but that is down the line.
Ice Blue - Beautiful!  :thumb:
« Reply #32 on: October 22, 2018, 11:19:25 AM »
Charlie, the early ones did not have a ribbed rectangular plate as a shoe kick.  I have the stock ones from my CX but I'm reluctant to grind off the mounting bosses to make it work, but that is another option.  I might be interested in purchasing yours.
Mine are the late type then. They've been powdercoated, but need a little straightening. The rider pegs point forward a bit.
« Reply #33 on: October 22, 2018, 12:11:39 PM »
Boot protectors are flat rectangles, later ones had vertical ribs embossed on the surface
Online blackcat
« Reply #34 on: October 22, 2018, 12:26:51 PM »
The one I have and the two that were on eBay have no boot protectors.
Offline Groover
    • Scooteropolis
« Reply #35 on: October 22, 2018, 01:42:34 PM »
Great job on that ice blue LM1 blackcat. Why does yours have the round taillight? Is that a 1977? Unfamiliar with the changeover on that detail.
1981 Moto Guzzi V1000G5
1987 Moto Guzzi LM1000SE, a
1987 Moto Guzzi LM1000SE, b
1980 Piaggio Vespa P200E
1980 Piaggio Vespa P125X
1980 Vespa Grande Moped
1980 Vespa SI Moped
http://scooteropolis.com/
« Reply #36 on: October 22, 2018, 03:11:31 PM »
I've found the bigger problem after I get is is forgetting where I put it........
Uhh, yeah. I know the feeling.
Offline Bill Owens
« Reply #37 on: October 22, 2018, 08:46:29 PM »
Why does that ice blue look O K on a SP but great on a Lemans?
« Reply #38 on: October 23, 2018, 11:59:55 AM »
Same reason a slinky black dress looks great on Heidi Klum but not so much on Rosie O'Donell   :wink:
Online Cam3512
« Reply #39 on: October 23, 2018, 04:54:16 PM »
BINGO!!
