Author Topic: Get 'em while you can... handlebar switches: SP2 LM4 T5 V65 Lario  (Read 5513 times)
Online bigbikerrick
Re: Get 'em while you can... handlebar switches: SP2 LM4 T5 V65 Lario
« Reply #1 on: October 26, 2018, 03:09:33 PM »
Thats cool Charlie, Thanks for posting this. Man, I wish they had the right hand side switches for a LeMans IV !
Rick.
Online bigbikerrick
« Reply #2 on: October 26, 2018, 03:13:36 PM »
MG Cycle does have the right hand switch ! I am going to order one, I have fidgeted around with the bad contacts on mine for years!
Rick.
http://www.mgcycle.com/index.php?main_page=product_info&products_id=5273
Offline LeRoy
« Reply #3 on: October 26, 2018, 03:14:34 PM »
...Man, I wish they had the right hand side switches for a LeMans IV !
Isn't that what this one is?
http://www.mgcycle.com/index.php?main_page=product_info&cPath=37_140&products_id=5273
I'm going to order the pair.
LeRoy (Bob Sharp)
Rochester, MI  U.S.A.
'83 1000SP (as of Oct. 15)
« Reply #4 on: October 26, 2018, 03:20:40 PM »
I linked to both in my original post.
Offline wirespokes
« Reply #5 on: October 27, 2018, 03:35:01 PM »
Are they normally not available?
Mine have been working fine the last two years and 16K - no issues at all.
« Reply #6 on: October 27, 2018, 04:02:58 PM »
Good, working ones are as rare as rocking horse poo normally. New ones are (were) pretty much unobtanium.
« Last Edit: October 27, 2018, 05:57:40 PM by Antietam Classic Cycle »
Online pehayes
« Reply #7 on: October 27, 2018, 05:52:17 PM »
I might go for a set.  Alas, looking at the inside picture I see that the wires are held in place by crimped rivets.  The heads of those rivets are rounded and serve as the contacting surface for the internal, brass sliders.  This was the base fault with the originals.  Connections get old, dirty, corroded and start to build heat.  As the rivets heat up, the heads recede into the surrounding plastic.  Thus making even less contact and generating more heat.  I cured mine by replacing the rivets with 2mm bolts and nuts.  Also by adding headlamp relays.  My mod has been good for years, but I'd still like to move up to newer (if not more modern) materials.
SPII
« Reply #8 on: October 27, 2018, 05:58:51 PM »
I would have been on them like a duck on a june bug when I was "doing" the Lario. As it was, LeRoy sold me some used but good switches at an under the market price.  :thumb: I put a bunch of relays on the AeroLario to keep them in service.
Yes, they have been like RHS (Roper content) for quite a while. I'll get these for spares before they turn into the same substance.
« Reply #9 on: October 27, 2018, 07:17:03 PM »
Got to be the junkiest switches they ever used, I toss that stuff in the trash and replace w/CEV that was on LM5's or SP3's or Duc's . Black w/orange buttons. In the day I got Moto Morini's, had a headlight off switch.
Last ones I got from Guzzi had the off switch too.
« Reply #10 on: October 27, 2018, 07:20:43 PM »
If you junk the switches, then you have to replace the front master cylinder, throttle and clutch lever. Could get kind of expensive...
« Reply #11 on: October 27, 2018, 07:39:39 PM »
Customer didn't mind at all, he had the cash.
Offline wirespokes
« Reply #12 on: October 28, 2018, 12:31:54 AM »
SPII
Thanks, Patrick! I can think with that.
The PO of my LM IV replaced the switches a short time before selling it to me. The old ones look good and don't understand why they were replaced. Now that I understand the situation, I'll be able to keep them working a good long time.
Online bigbikerrick
« Reply #13 on: October 29, 2018, 05:16:20 PM »
"If you junk the switches, then you have to replace the front master cylinder, throttle and clutch lever. Could get kind of expensive."
The above reason($$$)is why I have not replaced mine with something different. I think using these  switches now available,with relays , they will be fine, and they should last a long time.
I still have a hard time getting used to the weird turn signal switch. I usually just use hand signals when I ride the Le Mans!
Rick.
« Reply #14 on: October 29, 2018, 06:05:59 PM »
It's just like on your car.. <shrug>
(yeah, I know. I had problems with it too, until I thought of it that way..)
« Reply #15 on: October 29, 2018, 06:35:08 PM »
I know it's costly but customers want what they want. I get paid to do what they want. If a bike is 3-4 years old and and inside is melted or switches fall apart or little micro switches short. I trash it and put on better stuff. If you replace w/same it happens again.
Offline wirespokes
« Reply #16 on: October 29, 2018, 07:11:15 PM »
Rick.
It's easy - just think of it like this: in a right turn the left side handle bar comes up. Left turn - it goes down. The switch is exactly the same - up for right, down for left.
Online bigbikerrick
« Reply #17 on: October 30, 2018, 06:27:33 PM »
Thats a cool way to think of it Wirespokes! My wife  also told me" just think of it like the turn signal lever in a car...Up for right turn, and down for left turn"
I sure wish it would cancel by pressing the button in, like most bikes, returning the switch to center is tough sometimes when riding in crazy traffic!  :grin:
Rick.
Offline wirespokes
« Reply #18 on: October 30, 2018, 10:19:42 PM »
Rick.
I've got an answer for that one too. To activate the signal, press on the paddle part of the switch. When cancelling, press on the upper or lower section.
Often I don't instantly know which side to push, but it's easy enough pushing on the top side, and then the bottom side if not cancelled. It's more difficult activating the signals not using the paddle, but deactivating them that way works easily.
Offline jim mac
  • TOO OLD TO DIE YOUNG www.guzzriders.org
« Reply #19 on: November 01, 2018, 05:54:57 AM »
They didnt last long    :sad:
« Reply #20 on: November 01, 2018, 07:15:50 AM »
Gone already? They've been NLA for *years.*
Offline janguzzi
    • My YouTube Channel (Guzzi Content)
« Reply #21 on: November 01, 2018, 07:22:16 AM »
You can also order them in Germany:
https://hmb-guzzi.de/Sale
Kind Regards
Jan, Schuby (near the Danish Border), Germany
www.janguzzi.de
-1992-2002: 1000S, 2nd Series
-2002-2004: V11 Le Mans "Grigio Titanium"
-2004-2011: V11 Le Mans "Rosso Corsa" & 2008-2011: 950S
-2018-2021: California Vintage
-2011: Griso 8V & 2023: V85 TT "Giallo Mojave"
« Reply #22 on: November 01, 2018, 08:59:53 AM »
At twice the price...
« Reply #23 on: November 01, 2018, 11:30:45 AM »
Mine arrived from Cheesehead and Gordon yesterday. You snooze, you lose..  :grin:
Having spares means the switches I reworked when building the Lario will be good forever..
Online bigbikerrick
« Reply #24 on: November 01, 2018, 02:19:20 PM »
I was going to order a pair, but the right side switches quickly sold out. I asked Gordon when they will have more, and he responded in about 3 weeks. :thumb:
Wirespokes...Thats a great tip on cancelling the funky turn signals, I will give it a try
Rick.!
Offline Groover
    • Scooteropolis
« Reply #25 on: November 01, 2018, 03:48:29 PM »
How do the switches feel? Better, cheap-lier, or about the same as the OEM ones - just curious - it's great they are finally making reproductions!
1981 Moto Guzzi V1000G5
1987 Moto Guzzi LM1000SE, a
1987 Moto Guzzi LM1000SE, b
1980 Piaggio Vespa P200E
1980 Piaggio Vespa P125X
1980 Vespa Grande Moped
1980 Vespa SI Moped
http://scooteropolis.com/
« Reply #26 on: November 02, 2018, 08:49:08 AM »
Now you've done it. I had to take them out of the bag..I suppose that voids the warranty.  :smiley: They're fine.
Offline Groover
    • Scooteropolis
« Reply #27 on: November 02, 2018, 09:08:49 AM »
 :grin: Thanks for checking!
1980 Vespa SI Moped
