Author Topic: B10 CAM INSTALL  (Read 11645 times)
Rough Edge racing
Re: B10 CAM INSTALL
« Reply #30 on: December 05, 2018, 11:51:27 AM »
 A tighter lobe separation angle increases overlap and then to make a lumpier idle and favor a higher rpm power curve..
Offline pressureangle
Re: B10 CAM INSTALL
« Reply #31 on: December 05, 2018, 09:33:05 PM »
True, but 105* in these things isn't that. Mine idles enormously smoother than it did with the stock LM cam, and pulls harder all the way from idle to redline.
Rough Edge racing
Re: B10 CAM INSTALL
« Reply #32 on: December 06, 2018, 06:21:34 AM »
  Besides lobe separation, there's intake and exhaust lobe centerlines that influence the power delivery. Generally speaking, pushing both of them to a large degree number will smooth out the idle..Just for information, did you check the intake centerline?  Lot of variables with cam timing ...Good to hear you are satisfied !
Re: B10 CAM INSTALL
« Reply #33 on: December 06, 2018, 10:33:12 AM »
Rough Edge racing
Re: B10 CAM INSTALL
« Reply #34 on: December 06, 2018, 11:33:16 AM »
  To continue the story, what was the intake centerline in degrees ?
Offline Don G
Re: B10 CAM INSTALL
« Reply #35 on: December 06, 2018, 12:44:20 PM »
For what its worth, I was told that your lobe centerline should be no more than 4* from what the separation angle spec. is.  DonG
Re: B10 CAM INSTALL
« Reply #36 on: December 06, 2018, 04:59:54 PM »
The cam was dead onto the specs published, centerlines at 105.0*. (.0 in the sense that I don't have a four foot degree wheel lol)
IIRC I took the picture while finding the beginning of the ramp, I mapped the lift every 10* crank rotation to get acceleration rates and calculate spring pressure. The R&D spring kit Web sells is only good to about 7000 with the heavier valve train.
This cam was hand-made for me, so any tolerances in production may have been watched carefully- I had them grind a 1* taper on the lobes to match the radius of the Ford Y-block lifters I'm running over it.
Rough Edge racing
Re: B10 CAM INSTALL
« Reply #37 on: December 07, 2018, 05:53:41 AM »
 105 degrees intake and exhaust lobe centers is very typical of after market performance cams for the old Triumph 650-750 engines....The B10 cam timing, 20-50 at .050 lift is just a touch different than a 90'S Ducati 900 2 valve engine and a 60's Triumph 650 Bonneville..
« Last Edit: December 08, 2018, 06:47:59 AM by Rough Edge racing »
