Author Topic: The things you find..  (Read 28696 times)
Offline Don G
Re: The things you find..
« Reply #120 on: November 27, 2018, 11:59:35 AM »
What you have to do is clean the tank bottom, blast off the paint and rust etc. induce about 5PSI air pressure through a pet cock, don't over do it or the tunnel will bulge, as me how I know! Block the tunnel so it cant move, use a 4x4 or so piece of wood. Put a little water and dish soap mix on the whole bottom, have a cocktail and inspect for leaks.
« Reply #121 on: November 27, 2018, 12:04:53 PM »
Ewww, that's nasty looking, too..  :smiley: did you manage to save it?
« Reply #122 on: November 27, 2018, 12:15:15 PM »
Just had another thought.. I've lined a couple of tanks with Caswell epoxy that turned out beautifully. That might be cost effective..
You'd still need to get the old liner out though. That's the "hard part", especially if you don't want to repaint the tank. I removed failed POR-15 with MEK (just a gallon, tank turned to a different position every hour... for days, the vapor actually does the job), followed up with 1 1/8" fine drywall screws with the tank tumbling in the dryer on "fluff". I made this special cap to make sure nothing got out and ruined the paint.
http://thisoldtractor.com/moto_guzzi_loopframe_gas_cap_replacement_-_sacrificial.html
It's in no way "sacrificial", being more durable than the tank it was attached to.  :wink:
« Last Edit: November 27, 2018, 12:19:04 PM by Antietam Classic Cycle »
Online John A
« Reply #123 on: November 27, 2018, 12:44:35 PM »
Find a different tank, hopefully in better shape. might as well cut your losses now. Its like you said, you don't want a career out of a  stinking tank, looks like you could have 40 hours in that repair and unless its the last one available, it might not be worth it.
« Reply #124 on: November 27, 2018, 12:49:55 PM »
Nice, Charlie..  :thumb:
I just talked to Mark at Moto Guzzi Classics, and he said, "Sure, I have some tanks. How good does he want?" Then, in typical Mark fashion, he tried to talk me out of buying one,  :grin: and putting Caswell epoxy in it. "It's the only one that works."
Basically said the same thing to me, as far as installing it. He said, "Why not gamble 50 bux or so on acetone and a Caswell kit instead of 3-500 on a different tank?" You have to love him.. what a character.  :grin:
We're going to SoCal in 3 weeks, so I could pick out which one the owner gets if the Caswell doesn't work.
Personally, I think the owner should get the nicest one he has and be done with it.. but I'll talk to him about that. Since he's paying labor, that Caswell job won't be cheap, either.
« Reply #125 on: November 27, 2018, 12:51:27 PM »
Yeah, that's my thought, too, John..Shirley :smiley: I wouldn't have 40 (billable) hours in it, but it would be more than it's worth.
Online John A
« Reply #126 on: November 27, 2018, 01:03:18 PM »
Yeah, that "billable hours" concept will bite you in the butt :cry:
Offline Don G
« Reply #127 on: November 27, 2018, 05:00:20 PM »
Yeah I ended up saving that tank for now, it had a really nice original paint job, used 1 pound of silver bearing solder by time I was done, didn't record how many hours spent but it was a few.  DonG
« Reply #128 on: November 27, 2018, 06:32:14 PM »
Yeah, I get it. I can blissfully while away the hours on*my* stuff doing something like that. I can't when somebody is paying for my time. It just doesn't pencil out for them.  :smiley:
