Author Topic: Loop frame cam followers  (Read 3468 times)
Offline Guzzi relic
« on: November 15, 2018, 08:13:33 PM »
I'm starting to dig into one of my winter projects already --- my '74 Eldorado --- I've taken the top end down and will be replacing my original chrome bore cylinders with Gilardoni kits. As well it looks like I'll be doing guides and valves. Amazing how worn the guides are and the plugs were always clean and there was no smoke. But blow by has been getting worse lately.
But I digress; I've found some minimal pitting on two of the cam followers. I see that originals are NLA and MG, (probably others) sell a kit with a later design of follower along with matching push rod and rocker arm.
Is there any alternatives to these rather costly replacement kits?
Is there a possibility of finding good used followers? Or is this a common malady meaning used parts would probably be no better?
Thanks!
Ken
I wonder where this goes?
Re: Loop frame cam followers
« Reply #1 on: November 15, 2018, 08:26:29 PM »
Thanks!
Ken
Yes, the alternative is to have them refaced. I send mine to Delta Camshaft in Tacoma, WA. I just sent 24 to them today. Very reasonable cost.
Offline Guzzi relic
« Reply #2 on: November 15, 2018, 08:33:38 PM »
Thank you. I was wondering if this was a possibility. I'll check them out.
Or, do you have them done to resell or just for your own use?
Ken
« Reply #3 on: November 15, 2018, 08:39:39 PM »
Ken
I have them done for use in engines I rebuild and for anyone that wants a set. If you don't want to deal with Delta directly, you can get a set from me, I'll need yours in exchange.
Offline Guzzi relic
« Reply #4 on: November 15, 2018, 09:09:52 PM »
Ok great. Dealing with you would be easier for me. Is it best to contact you through your website?
« Reply #5 on: November 15, 2018, 09:46:07 PM »
Just drop me an email: c.d.mullendore@att.net
Loop Tonti EV
« Reply #6 on: November 15, 2018, 11:51:38 PM »
Charlie is an asset to the Guzzi family. You won't be sorry when dealing with Charlie.
« Reply #7 on: November 17, 2018, 06:15:35 PM »
k
+1 on Charlie !!
« Last Edit: November 17, 2018, 06:16:09 PM by John A »
Offline Guzzi relic
« Reply #8 on: November 17, 2018, 07:12:07 PM »
+1 on Charlie !!
[/quote]
Yes! (We are doing business)
 Thanks to the WG forum, such a great help for all of us.
Ken
« Reply #9 on: November 17, 2018, 09:02:17 PM »
Offline Lesman
« Reply #10 on: November 23, 2018, 12:50:44 PM »
I used Delta. Great turn around time. Might want to upgrade the cambe to a B10? setup. Cam & 4 lifters was in the $150-$180 range. Part of that was Postage.
