Author Topic: NGC - Need a conductive adhesive...  (Read 2649 times)
Offline brider
« on: November 21, 2018, 08:16:05 AM »
...that will cure in low temps to re-bond the electrical clip to my car rear-window defroster grid.
Permatex (I think) makes an epoxy for just this application, but it needs 50-70 deg temps to cure properly, and I ain't got that in my garage now:
https://www.permatex.com/products/specialized-maintenance-repair/defogger-repair/permatex-rear-window-defoggerelectrically-conductive-tab-adhesive/
Has anyone used a different conductive adhesive that might cure at a lower temp? I have to ask before rigging up a hair-dryer to blow on the area for a couple of days.
Thanks,
'85 Cal II Auto
'71 Ambo project
'02 GasGas EC300
'07 Norge
'05 KTM 950 Adventure
Wish'd I'd never sold:
'72 Red Eldo
'74 White Eldo LAPD
'77 Convert with DB bags
'06 Gas Gas EC300
'86 LM IV
Re: NGC - Need a conductive adhesive...
« Reply #1 on: November 21, 2018, 10:35:38 AM »
I have a conductive paint, that dries like any normal lacquer. I have one that is copper filled, and one that is nickel filled. You can use them to repair damaged spots in the grid, but I would not call them adhesives.
I would use an extension cord, hair drier, and that epoxy.
Offline Toecutter
« Reply #2 on: November 21, 2018, 10:59:49 AM »
A propane tank-top heater would cut that time down considerably.
Offline pehayes
« Reply #3 on: November 21, 2018, 12:50:16 PM »
I have this among my soldering tools:
https://www.amazon.com/MG-Chemicals-Silver-Epoxy-Adhesive/dp/B008UH4DB2/ref=sr_1_4?ie=UTF8&qid=1542825890&sr=8-4&keywords=conductive+epoxy
Says 5 hour cure at 77F.
Surely you can set a small, thermostatically controlled electric heater inside the car to keep the interior around 70.  Experiment with that for a day or so until you can acquire the adhesive.
Offline yogidozer
« Reply #4 on: November 21, 2018, 01:55:26 PM »
Why not just redneck it on with ductape ?
« Reply #5 on: November 21, 2018, 02:37:47 PM »
How long to cure?  You could start the car with the heater running.
Offline brider
« Reply #6 on: November 21, 2018, 04:59:13 PM »
Ok, so it sounds like I need to solve my previous post about a garage heater first. And that idea about duct tape has me thinking....it might work with some of that aircraft 600-mph tape I have and a new connector that Amazon sells...
'85 Cal II Auto
'71 Ambo project
'02 GasGas EC300
'07 Norge
'72 Red Eldo
'74 White Eldo LAPD
'06 Gas Gas EC300
'86 LM IV
Offline pat80flh
« Reply #7 on: November 22, 2018, 05:28:58 AM »
SilverSolder and a small butane torch. Pain in the ass to hold the tab against the glass with long needle nose, torch and solder at the same time, but when you get it, it's good.
  I've never had any luck with the permetex product.
00 Bassa
80 FLH (in rehab)
75 850T prject
Offline redrider90
« Reply #8 on: November 22, 2018, 11:25:44 AM »
On a sunny day you can easily get 70º. Warm it up faster with the heat on and then park it in the sun.
Red 90 Mille GT
Offline Testarossa
    • Skiing History
« Reply #9 on: November 22, 2018, 11:54:58 AM »
Offline gearman
« Reply #10 on: November 23, 2018, 06:59:18 PM »
I have soldered the rear glass with a gun and good prep. No problem
