Author Topic: Horn Install  (Read 3761 times)
Offline davedel44
Horn Install
« on: December 03, 2018, 07:41:03 PM »
Trying to install new louder single hor to replace the 2 weak horns on my 2013 V7 Stone.  New horn is rated at 5amp old horns 1.2 amps each.  Removed old horns plugged in new and it works great.
Now I have extra set of wires.
Was advised to splice the extra set together, but when and pressed horn button the horn fuse blew.
Ideas?
Suggestions?
Dave
Galveston
Bambino- 2013 V7 Stone
Re: Horn Install
« Reply #1 on: December 03, 2018, 07:46:24 PM »
 Don't honk the horn until you really need to ?
Re: Horn Install
« Reply #2 on: December 03, 2018, 07:47:42 PM »
Ideas?
Suggestions?
Dave
Galveston
Under the "If It Hurts When You Do That ... DON'T DO THAT!" rule, don't "splice" anything .... just slip a piece of shrink tube over the ends of each of the old wires, fold them back, and zip-tie them out of sight ....
Offline davedel44
Re: Horn Install
« Reply #3 on: December 03, 2018, 08:00:48 PM »
And a big OKC Skyline salute to you.  You told me told me to do it.
Dave  Galveston
Offline davedel44
Re: Horn Install
« Reply #4 on: December 03, 2018, 08:02:54 PM »
Thanks Lannis.
Dave
Re: Horn Install
« Reply #5 on: December 03, 2018, 08:58:58 PM »
Dave  Galveston
 You neglected to tell me the wires are different colors  :tongue:
Offline davedel44
Re: Horn Install
« Reply #6 on: December 04, 2018, 07:49:13 AM »
Where is that report to moderator button.
Fixed it
Re: Horn Install
« Reply #7 on: December 04, 2018, 08:57:57 AM »
Normally, one is power, the other is ground. Hooking them together and pushing the button causes a dead short. If the fuse *doesn't* blow.. "Houston, we have a problem.."  :smiley:
Offline davedel44
Re: Horn Install
« Reply #8 on: December 04, 2018, 09:08:44 AM »
Thanks Chuck.
Offline PJPR01
Re: Horn Install
« Reply #9 on: December 04, 2018, 09:44:00 AM »
Beep beep!  Watch out...Galveston Dave coming thru!
Paul R
2015 Red/Black Griso
2008 Silver Norge
2002 V11 Scura
Re: Horn Install
« Reply #10 on: December 04, 2018, 10:50:18 AM »
That's smoke signals for the deaf
Re: Horn Install
« Reply #11 on: December 04, 2018, 11:16:39 AM »
 :grin:
Offline Lesman
Re: Horn Install
« Reply #12 on: December 04, 2018, 12:43:45 PM »
Get a horn you can be proud of. Wolo or Steibel. 17 amps of pure primal pleasure. You would need a relay and a separate fused line to the battery.
