Author Topic: Loop carrier bearing snap ring dimensions  (Read 1019 times)
Offline Don G
« on: December 10, 2018, 09:19:41 AM »
I am short a snap ring for the U-Joint carrier bearing, anyone have the dimensions as I will likely look local for one. I do know the bearing is 58mm OD, what would the width of the snap ring be?  Thanks DonG
Offline Don G
Re: Loop carrier bearing snap ring dimensions
« Reply #1 on: December 11, 2018, 08:46:41 AM »
The I is likely designating it as internal, I found one in my stash, it measures 2.430"OD and is .078" thick. The one you showed will likely do as well, thanks for the effort!  DonG
