Author Topic: 96 sport 1100  (Read 8325 times)
Re: 96 sport 1100
« Reply #30 on: December 17, 2018, 06:41:50 PM »
That looks refreshingly unmollested. :thumb:
Online RinkRat II
  • Lake Powell AZ
Re: 96 sport 1100
« Reply #31 on: December 17, 2018, 07:32:45 PM »
      I see you've already enlisted the factory technician to set the ergo's up for you! A few more years and He'll sure be glad you bought this for him :evil:
        Paul B :boozing:
Offline Turin
Re: 96 sport 1100
« Reply #32 on: December 17, 2018, 07:49:49 PM »
Since it has sat for three years the carbs may be gummed up. Pull the carburetor bowl drain plugs. What you see in the bottom of the drain plug will be an indicator of what the inside of the carb looks like. If it falling
 on its face when opening the throttle, sounds like a dirty needle and needle jet, or maybe a clogged main jet. Easy enough to check.
This was my first thought. I've had luck dropping the float bowls and letting a bit of fresh gas dump through, and then giving an Italian tune up.
1985 Sidlow Guzzi
Offline Devildog
Re: 96 sport 1100
« Reply #33 on: December 18, 2018, 05:15:54 PM »
Thanks Stephan. 'Definitely an acquired taste" is a good way to put it.
'93 Daytona 1000
'95 Sport 1100
2002 Aprilia RSV Mille R
'10 GasGas e250 FE
