Author Topic: 1984 BMW R100 value help  (Read 13499 times)
Offline xackley
Re: 1984 BMW R100 value help
« Reply #30 on: January 01, 2019, 11:56:36 AM »
The main thing to remember is to tip it to the right before parking on the side stand. At least true for older models.
1958 R69 BMW, 1972 R75/5, 1980 yamaha XS650, 1982 GL1100, 2003 EV, 2007 Triumph America and 2017 V7!!!
All on the road, going nowhere in particular.
Offline wirespokes
« Reply #31 on: January 01, 2019, 11:59:17 AM »
81-84 had the valve recession problems. The valve seats were changed anticipating trouble with unleaded, but it was a poor move and the seats didn't flow heat very well. The exhaust valves would over-heat and tulip. A work-around was larger valve settings allowing the valve to rest on the seat longer transferring more heat.
They're still rideable with that going on, you just need to check rocker clearance more often. If the gap closes down to nothing, they're difficult to start and it's obvious - pull the rocker cover and adjust. It's not like the bike is down till the work is done.
That's a pretty one radguzzi.
After 1984, all of the engines were variations of the 800. Same cylinder heads and carbs. I think all of the cams were the same before that. The heads were changed in 85 and are supposed to flow much better than the earlier ones, but power was down with the lower compression.
I totally agree - $500 for just a parts bike is an incredible deal these days.
Offline Gappy
  • StLouis MO
« Reply #32 on: January 01, 2019, 01:59:51 PM »
I am new to this form just have bought a 1994 California 1100 carburated, I have been riding airheads since the 70’s an  r75/5. Currently own 2 r100rt’s, an 81 and an 88. I concider the California an airhead so I am not out of my element.
 The Machine you are looking at is worth more than 500 dollars even if it doesn’t run. It would not take much to make it run smoothly again, a lot of maintence very little parts if any, It would be in my garage already if it were near me.
  Don’t let the valve recession scare you , as long as you have adjustment in the rockers you will be ok, when time comes you can fix this if done properly. To many people think they know how to recut the heads and put in the valve seats and valves and end up with a bad job, you need to find some one who is qualified to do this and there are only a few in the country that can do it right in my opinion.
  It sounds like this bike has some good bones and would be worth while to buy, the secret to these machines is to do your own wrenching when all possible. Dealship labor is very expensive on these bikes for what they do.
   If you buy this bike you need to join airheads.org, a group dedicated to these bikes, good luck.
2003 Suzuki burgman an650
1994 Moto Guzzi California 1100
1992 BMW k75s
1983 Harley Davidson FLHT
1981 BMW r100rt
1981 Honda 650/4
Offline Gappy
  • StLouis MO
« Reply #33 on: January 01, 2019, 02:19:03 PM »
One more thing, I would guess that 95% parts of this bike can be purchased at a bmw dealer, 100 % of the important ones , things like gauges, and body parts are na. But they are out there used and no problem to find. Most guys I know including myself keep these bikes running with good used parts at a fraction of the cost of new.
1992 BMW k75s
1981 BMW r100rt
1981 Honda 650/4
Offline Perazzimx14
« Reply #34 on: January 01, 2019, 03:18:29 PM »
The sellers and my schedules didn't line up today so I didn't get the bring the BMW home today. Postponed until later in the week.
« Reply #35 on: January 01, 2019, 03:25:33 PM »
I'll buy it if you change your mind.
Offline Perazzimx14
« Reply #36 on: January 01, 2019, 04:23:40 PM »
I'm still buying it just waiting to hear back from the seller what day works for me to P/U.
Offline wirespokes
« Reply #37 on: January 01, 2019, 05:20:20 PM »
Can I ask why?
If you don't there's a good possibility it'll smoke on start up. There's a lot of oil splashing around in there while the engine's running. Turn it off and it settles behind the pistons and in the bores. The right side will be tilted up, so it'll drain. But the left side being tilted down will see the oil pooled against the piston. Since rings don't seal perfectly, the hot oil, being thin, can wiggle its way into the combustion chamber.
So either tilt the bike to the right for a minute or two, or park on the center stand.
Offline Gappy
  • StLouis MO
« Reply #38 on: January 01, 2019, 08:31:05 PM »
Tilting the bike to the right will only ruin your back and possibly dump oil into the right cylinder if you can tilt it as far as the right kickstand leans them. You are right about putting on the center stand, the airheads pre 85 were not ment to spend much time on it side stand, so aftermarket side stands were made to allow the bike to sit more upright. Both of mine have brown side stands. I also do not run the bike full of oil ,only in the running range and both bikes are happy with that and I have very little smoke after setting for days coming out of the right cylinder at start up.
1992 BMW k75s
1981 BMW r100rt
1981 Honda 650/4
Offline Gappy
  • StLouis MO
« Reply #39 on: January 01, 2019, 08:34:10 PM »
I ment left cylinder
1992 BMW k75s
1981 BMW r100rt
1981 Honda 650/4
Offline Gappy
  • StLouis MO
« Reply #40 on: January 01, 2019, 08:38:36 PM »
1992 BMW k75s
1981 BMW r100rt
1981 Honda 650/4
« Reply #41 on: January 01, 2019, 08:51:39 PM »
 OK man , we heard you the first time  :grin:
Offline xackley
« Reply #42 on: January 02, 2019, 10:52:03 AM »
Yes, just lean it against your right leg  for a few seconds should do it, doesn't take much unless you want to make sure when it will be setting for a while. And as said above, optimum oil level is half way between full and add. I have a 1958 R69 and an R75/5.
For final sync of the carbs I leave the left cable adjustment lock nut loose and go out riding. Stop, twitch the screw a little, take off. Repeat until as smooth as possible when accelerating and at speed. Then tighten the locknut.
Of my 6 motorcycles. my EV is my new favorite, even over my all time ultra favorite R69.
Don
Offline Perazzimx14
« Reply #43 on: January 02, 2019, 01:47:22 PM »
Well I'm supposed to pick up the R100 Saturday morning. I'll fiddle with it a little to see if it runs or wants to run on Saturday. The it'll be a late winter project as I have some other motorcycle maintenance I want to get caught up on my everyday whip :thumb:
Stay tuned
« Reply #44 on: January 02, 2019, 07:21:37 PM »
Stay tuned
As with high mileage Guzzis, these older BMW flat twins have their own unique issues.  I recently had a very good BMW technician who now works as an independent shop do a bunch of work on my 1991 R100GS.  I was at $1100.00 in replacement parts before the driveshaft was pulled, and found to be shot.  Add $700.00 to the parts list.
Now, to be fair, some of the replaced parts may not have been totally shot.  But a carb rebuild was in order, and the tranny was dismantled, all shaft bearings replaced, along with shift mechanism wear items.  Petcocks were 27 years old, one weeped fuel, so both these were replaced.  Clutch plate and diaphragm springs also replaced.  Amazingly, the pressure plate still had some of the machining marks on it.  I do treat these single plate clutches with some respect.
Guess the point of what I'm saying is ....... just like Guzzis, old airheads have a lot of parts that need replacement periodically. Be prepared to shell out some cash to get this old gal in shape, especially if you're going to farm out the labor.
Happy New Year!
Bob
« Reply #45 on: January 02, 2019, 07:52:34 PM »
But, also like old Guzzis, after this is all done, it'll go another 150k miles.
Offline xackley
« Reply #46 on: January 02, 2019, 07:57:48 PM »
my 1958 R69 has 64,000 on it, I put on everything over 14k  since 1977. I replaced the clutch a couple years ago. The rivets gave way. That's it for mechanical failures. It still cruises at 70mph on the 4 lane.
« Reply #47 on: January 02, 2019, 09:01:53 PM »
I'm hoping!  Well, as I approach my 76th birthday in January of 2019, the question of my R100GS making it for another 150,000 miles (with me doing the riding,) is purely academic!  Or pure fiction!  It took me from 1991 to 2018 to put the first 156,000 miles on the old gal. Not sure I'm up to doing this again.
Bob
« Last Edit: January 02, 2019, 09:06:35 PM by ohiorider »
Offline wirespokes
« Reply #48 on: January 02, 2019, 10:23:09 PM »
Sure you are!
A lot of times these bikes can be wakened from a long slumber with very little work. Usually, the carbs need cleaning and a few jet o-rings replaced. Jets don't need replacing - maybe the needle and needle jet if they're worn. I've rarely replaced the diaphragms and don't recall the last time. So rebuilding carbs (at great expense) isn't usually necessary. But cleaning, yes.
Transmissions can fail, no different than any other car or bike. Rather than pulling it and opening it up to see what sort of shape it's in, just ride it. If it's noisy, pops out of gear, shows slivers and chunks in the drained oil, well, yeah - tear into it.
Sometimes the petcocks leak. They're easy to disassemble. Water settles to the lowest spot in the tank which will be the petcock. The flow is stopped by the selector disc that's part of the handle. So what happens is the water pits the aluminum disc which then doesn't seal off the flow anymore. The solution is to carefully file away the pitting and polish it up. That usually solves it. I've found this to be true of Guzzi petcocks as well.
The other issue with older bikes whether they've been sitting or not is electrical connections. Those two things, electrical connections and carb cleaning are the two main things that usually need attention. Seals my leak and need replacing, or maybe not. When the shaft dries out (oil has completely left) the seal can chatter on first start up. It's possible the spring can fly off and then for sure it will leak. So the solution preventing that possibility is turning the engine and trans over by hand getting oil pumping or splashing everywhere needed. And once the engine is first started, keeping RPMs low. Run it through the gears while on the center stand.
Some guys go in and replace everything that's not absolutely perfect. That's one way of doing it, but I prefer replacing only what's needed.
I've got an 85 LM parked in 91. What I just mentioned was what it took to get it running again. I've gotten many airheads running this same way since 1990. About 1995 I got what I figured was a parts bike (1974 R90) because it looked awful (sitting under a tarp for about three years, then another two after the tarp disintegrated) but going through this procedure brought it back to my surprise. I did have to replace just about every seal after I started riding it. It goes that way sometimes.
So don't get the idea you'll have to rebuild the carbs ($200 in parts) or a transmission for a grand. I hear this all the time - needing to rebuilding carbs. Jet's don't wear out - it's only the needle and needle jet. Even diaphragms last a long time, and even when they fail, it's not a disaster. The bike will run, just not the best. So it's a pet peeve of mine rebuilding carbs, when a good cleaning will do the trick.
Post some pix of the bike when you get it home.
Offline Perazzimx14
« Reply #49 on: January 03, 2019, 09:32:27 AM »
Happy New Year!
Bob
Having been there done that. I won't let it become the money suck the Eldo, 850T or the T3 were. I'm going in guarded on this potential revival. I have budget in mind and although its not thousands of dollars its a decent amount. I'm also only worried about the mechanics of the bike and not the aesthetics. If I can make it a reliable runner I really don't mind if its a frankenbike or crusty.
Once I get the bike home I can more thoroughly access the bike and if the budget is enough to make it a reasonably reliable rider. If it is I'll place my orders and get to work. If not.......well I cross that bridge when I come to it.
« Reply #50 on: January 03, 2019, 09:49:09 AM »
Best of luck in bringing this Fraulein back to life!  There's plenty of on-line expertise and a bundle of parts available for these old airheads.  Combine that with your love of resurrecting older bikes, I'm sure you'll be riding the Beemer this spring/summer.
I rode my '91 GS out West in 2005 and again in 2009.  Took the 1200 Sport in 2011.  Thinking I'd like to get in another R100GS ride to Utah this summer, and am trying to make the old gal as dependable as possible.  Therefore the reason for many of the new parts.
Bob
Offline Perazzimx14
« Reply #51 on: January 03, 2019, 04:55:51 PM »
Got a text from the seller today saying the bike is sold :shocked:.
I text back if it fall through I have cash waiting and am free Saturday morning.
« Reply #52 on: January 03, 2019, 05:07:32 PM »
Bummer. Wasn't me.  :wink:
« Reply #53 on: January 03, 2019, 05:42:35 PM »
I've learned over the years, when you find a good deal, you need to complete the deal ASAP, if not, they often fall through.
And, for the record, it wasn't me either.
« Reply #54 on: January 03, 2019, 05:54:10 PM »
Late 80's-early 90's  were the best R1000's made. 95's were junk, many had vibes cause molds were past due to be replaced. That's why they quit making them then brought them back.
Offline Perazzimx14
« Reply #55 on: January 03, 2019, 05:57:57 PM »
I tried but we had conflicting work schedules during the week. While I'd have liked to have gotten the BMW this might be the incentive I needed to start working on the 850T again. Its a lot further along (especially financially) than the BMW would have been.
I'm also on the lookout for a 850T frame, swingarm and triples in good condition and cheap.
Offline Perazzimx14
« Reply #56 on: January 03, 2019, 06:00:28 PM »
I'm not on the hunt for a BMW especially an older one. This just presented itself and for the money was worth a shot. If I was truly looking for another project It'd be another 70's era Guzzi.
« Reply #57 on: January 03, 2019, 06:10:18 PM »
I might have some triples for you. Cheap. Off of the frame in the foreground.
« Reply #58 on: January 03, 2019, 07:19:11 PM »
At least your 850T is a known quantity to you know.
What's wrong with the frame, swing arm and triples?
Offline Perazzimx14
« Reply #59 on: January 04, 2019, 05:15:41 AM »
Fortunately nothing is wrong with the T other than cosmetics.
Frame, swing arm and triples are for another project.
