Author Topic: actual CalVin oil capacity ?  (Read 15545 times)
Online kballowe
  • - Kevin the Great -
« on: January 07, 2019, 11:45:27 AM »
So, what's the WG recommended motor oil fill (with filter) for a 2009 California Vintage 1064CC ???  Book says three liters.
I only ask this question because (sometimes) using the book-listed oil capacity will have motor oil flowing in places where it shouldn't.  A google search turned up nothing.
Thanks,
Kevin
Online Ncdan
Re: actual CalVin oil capacity ?
« Reply #1 on: January 07, 2019, 12:15:31 PM »
Thanks,
Kev, when I changed mine, if it was time for the filter also as I did that every other change, I'd fill to about a 1/4 inch from full on the stick, start and run a minute or two to fill the new filter, then just keep adding until it got to the full line. This is what we go by anyway before adding oil. This way I never got to much or to little oil.
Kevin
Offline Peter949
  • PeterCaliII
  • 84 Cali II
« Reply #2 on: January 07, 2019, 12:58:53 PM »
On my 2004 California EV  I always put in 3.0 Litres along with a new filter. Never any extra, and the oil level on the dipstick would show a little low after adding exactly 3 litres.   :bike-037:
Peter
1984  Cali II
Aprilia 125 Sportcity Scooter
« Reply #3 on: January 07, 2019, 03:41:56 PM »
New filter in pan w/o oil in it, cause it comes out otherwise. 3 qts/lts in and start it, run a bit, shut off & top up till you're satisfied. I never have oil anywhere it shouldn't be.
Online Mr Revhead
« Reply #4 on: January 08, 2019, 03:27:32 AM »
My 03 EV I fill by volume, 3 litres. This has it about 10-15mm under the full mark. If I fill to full it leaks badly around the rear bearing gasket and drips out the bell housing making a prick of a mess.
Also filling to the full mark takes about an extra 400mls.
« Last Edit: January 08, 2019, 01:12:01 PM by Mr Revhead »
Offline janguzzi
    • My YouTube Channel (Guzzi Content)
« Reply #5 on: January 08, 2019, 04:24:42 AM »
And always remember to tighten the oil filter with the right torque.
The oil level check should be carried out after the engine has run for a few minutes:
the dipstick plug should be introduced in the oil opening without screwing it.
Kind Regards
Jan, Schuby (near the Danish Border), Germany
www.janguzzi.de
-1992-2002: 1000S, 2nd Series
-2002-2004: V11 Le Mans "Grigio Titanium"
-2004-2011: V11 Le Mans "Rosso Corsa" & 2008-2011: 950S
-2018-2021: California Vintage
-2011: Griso 8V & 2023: V85 TT "Giallo Mojave"
« Reply #6 on: January 08, 2019, 05:06:38 AM »
After you have changed the filter which you should pre fill as much as possible bolt the sump back on and throw three litres in. Run it for thirty seconds an leave it for a couple of minutes. Check where the level is on the stick. You're good to go.
If when you're riding it *uses* a bit of oil don't add any more unless it drops below the 'Add' mark on the stick. It probably won't and if it does? Well you have other issues. Don't keep topping it up. It's got tons of oil. If you put three litres in it isn't going to go 'Pop!'
Offline e.cleven
« Reply #7 on: January 08, 2019, 07:04:10 AM »
Soooo, is the bike supposed to be on the side stand or the center stand when you check the oil?? This question coming from a guy who has owned Guizzies since 1985.. You would think I would know by now but I always have to think about it.
I also own a 08 Calvin.
Ride safe.
Earl
Offline Texas Turnip
« Reply #8 on: January 08, 2019, 07:35:12 AM »
Ride safe.
Earl
Earl,
I've been checking it on the centerstand since 1971 and well over a million miles. No problems.
Tex
Offline e.cleven
« Reply #9 on: January 08, 2019, 07:39:46 AM »
Ken, I know they do thing different in Texas, so dose that apply to other part of the country as well??
ken
Online kballowe
« Reply #10 on: January 08, 2019, 10:08:15 AM »
Well, now that we have THAT out of the way.
How about transmission and shaft drive lube ?
The book says 80W-90 for both.
Yes ?
« Last Edit: January 08, 2019, 10:08:39 AM by kballowe »
Offline Steve Scott
  • Ride, Fettle, Repeat
« Reply #11 on: January 08, 2019, 01:09:01 PM »
I've always filled my big block with precisely 2.84 liters.
(In other words I dump in 3 quarts)
'79 Morini 500S
'00 'Guzzi Jackal
'67 Teisco ET-440
Spring Grove, PA USA
Offline janguzzi
« Reply #12 on: January 08, 2019, 02:50:36 PM »
Oil check on the center stand or in horizontal position.
I have mentioned this:
because this is different to older Californias or Guzzi models!
This is valid for all Californias with twin spark ignition (TECHNICAL BULLETIN NR. 001-2006 16.02.2006 + owner´s manual).
Kind Regards
www.janguzzi.de
Offline janguzzi
« Reply #13 on: January 08, 2019, 02:59:15 PM »
80W90 for both. Avoid synthetic oil (e.g. 75W140). This can lead to leakages because of shrinking or swelling the rotary shaft seals.
Kind Regards
www.janguzzi.de
Offline Dilliw
« Reply #14 on: January 08, 2019, 03:06:57 PM »
  :bow: :thumb:
And after Wayne fixed a leak I've never added a drop between changes.  So easy even a Guzziti can do it :)
George Westbury
Austin, TX
Offline Richard Tasmania
  • Tasmania, Australia
« Reply #15 on: February 11, 2023, 12:46:46 AM »
Sorry, I know it is an old topic but think not worth starting another.
When I fill mine correctly, (new filter, center stand, 3 litres) it comes out the back making a mess around the rear wheel. My last oil change was 5,00 km ago and I had been keeping the oil level up until recently when I became sick and tired of all the mess around the back wheel. I cleaned everything last week, checked the oil and it was on the bottom of the dipstick. Ran it for 500 km and no oil around the rear tyre. I took the sump plug out now, oil is clean, only 1500 ml came out. There is probably 500 ml in the filter?
V50III gone but not forgotton
V7C 2012
California Vintage 2007
V50 Monza 1984
V7 Special 2022
Online Mr Revhead
« Reply #16 on: February 11, 2023, 12:50:31 AM »
Where is the oil coming out?
You either have a leak: rear main or rear main carrier)
Or most likely the drains into the heads are blocked meaning the crankcase ventilation isn't working and filling with oil, it then fills the air box which has an overflow that exits just behind the gearbox.
So do you have oil out the bel housing? Or the hose?
« Reply #17 on: February 12, 2023, 07:48:08 AM »
Kevin, Did you get yourself a Cal Vin?
« Reply #18 on: February 16, 2023, 04:03:25 AM »
Thank you very much.
I checked the air filter. There was a tablespoon of oil in it but I could not find an outlet.
I washed thoroughly under the bike and topped up to a total of 2800 ml oil. No problem after 1500 km except when I really gave it to her and revved her hard up a large, long, twisty hill. Then a couple of drops came out but hard to tell from where.
I am mystified, but happy. Maybe I cleaned a blocked hose?
Sadly when I checked in the air filter there was a lot of dust bypassing the filter but that will be another thread I will search.
Thanks again.
V7C 2012
V50 Monza 1984
V7 Special 2022
Online Mr Revhead
« Reply #19 on: February 16, 2023, 12:03:42 PM »
The out let is mocked into the left side if the airbox I think.
For the dust, check the intake tube running from the box to the inlets, the seals around them can dislodge and also go hard.
I had one on a Sport 1100 I had where I had to wrap tape around the tube to build it up to seal until new ones arrived
