Author Topic: Sport1100i Wheels on carb Sport?  (Read 3931 times)
Offline Kristian
« on: January 24, 2019, 06:31:18 PM »
Has anyone swapped Sporti wheels onto a carb Sport or Daytona? What's involved?
Thanks-
Re: Sport1100i Wheels on carb Sport?
« Reply #1 on: January 24, 2019, 07:56:07 PM »
Cush drive, trade ya, I need a non cush drive.
Offline radguzzi
« Reply #2 on: January 24, 2019, 09:28:52 PM »
Thanks-
Kristian,
As I recall there is a width difference with the Sporti rear wheel and that the earlier swing arm is too narrow to use the 17" rim.
I'll dig back and do a little more searching in my notes, I owned both models.
Rob
08 Norge 1200 GT
04 EVT
01 V11 Sport
'99 EV Hack
'76 V1000 'Vert
'86 LeMans 1000
'80 SP 1000 Two (2) actually
2013 Harley FLHTC
'75 Triumph T160 Trident
'78 Triumph T140V Bonneville
'76 Honda CB550 Four
'88 Honda Hawk GT
'84 RZ350 KR
'71 Dalesman Trials
'68 VW
'73 MGB
The Journey is the Reward
jwinwi
« Reply #3 on: January 25, 2019, 06:21:45 AM »
Haven't one it myself but IIRC you need to change the rear brake caliper mount to the Sport i type.
« Reply #4 on: January 25, 2019, 10:27:15 AM »
Thanks-
Front will require different bearings, as the axles are different diameters between the Carb Sport and Sport Injection.
Rear will require everything.  The wheels are the same width and use a 160 section tire, but...
With differences in the bevel box and drive shaft, you'll need those from the Sport Injection, plus the brake caliper bracket.
And here's the obligatory question:  Why do you want to swap the wheels?  There are plenty of tire choices for the 18" rear.  I've owned a Sport 1100 for 22-years and have never had an issue with getting sport or sport-touring rubber for the bike.
Offline Kristian
« Reply #5 on: January 25, 2019, 11:30:34 AM »
I thought as much re the front; the driveshaft and axle are the same, and I suspect the rear drive box is not very different. No matter, too much trouble, even if the stock wheels are the heaviest in creation. I came across a cheap set of i wheels; cush drive, lighter, etc.
« Reply #6 on: January 25, 2019, 12:11:25 PM »
Every Carb Sport owner goes through this.  I did, early on.  One time, years ago, I weighed the stock wheels and was shocked at how heavy they are.  I thought of going with the then-available Dymags, but cost kept me from doing it.
The swap you are contemplating can be done.  It's just not a direct bolt-on.  You should be able to locate a cush-drive bevel box.  I just don't know if the relatively small weight savings between the stock carb Sport's Campagnolos and the Sport Injection's Marchessinis would be worth the effort.  If I was going to do it, I'd want forged wheels that would provide a significant weight savings.
Offline Kristian
« Reply #7 on: January 25, 2019, 12:35:44 PM »
Yep, just had them off for new skins; they are LOL heavy! OTOH, it ain't a Panigale and never will be, so well enough is fine. Plus it handles just fine with the rider-weight matched Ohlins springs front/back and a little commitment. If it was an easy swap, might be worth it.
Offline pauldaytona
    • Paul's fast Guzzi Page
« Reply #8 on: January 25, 2019, 03:03:09 PM »
The front Marzocchi forks are less wide, so the disks will scratch against the fork legs. So need the WP forks too.
Paul
Daytona 1225, Stelvio 1151
Offline Kristian
« Reply #9 on: January 25, 2019, 05:37:20 PM »
Thanks, Paul. The moment it was just a bit more than slight trouble, I forgot about it!
