Author Topic: NO JOY YET< No Cranking issue in cooler weather  (Read 16250 times)
Re: NO JOY YET< No Cranking issue in cooler weather
« Reply #60 on: April 01, 2019, 09:39:44 PM »
I told you in 44 to get rid of the MPH relay and power the original Guzzi relay socket direct from the battery through a new fuse.
You have a weak joint somewhere, I suggest you replace the wire all the way from the battery to the relay 30 and back from the relay 87 to the solenoid.
It's a well known fact that the original Breva wiring is suspect your troubles seem to have migrated from the original to the MPH kit.
If the factory bothered to draw the starter properly they might wake up to the problem.
To keep this new wire somewhat the same as the drawing you might like to make it yellow No 14
Make sure the spade connector at the solenoid is good quality and freshly crimped with some grease on the wire first.
Perhaps run this wire by the battery terminal so in an emergency you can touch it to the battery and hot wire the starter, if you do this slip a little tube over the bare spot.
« Last Edit: April 01, 2019, 09:48:53 PM by Kiwi_Roy »
Offline flower_king001
« Reply #61 on: April 02, 2019, 12:36:22 PM »
 :violent1:
« Last Edit: April 02, 2019, 12:36:39 PM by flower_king001 »
1971 BMW R90/5
1998 Moto Guzzi 1100 EV
2005 BMW 1200 RT
2007 BMW 1200 GS
2007 Moto Guzzi Breva 1100
Offline Kiwi Dave
    • Guzzi Gander Ltd
« Reply #62 on: April 02, 2019, 01:46:13 PM »
:violent1:
I agree.  And it's only taken three pages.
« Reply #63 on: April 02, 2019, 06:25:34 PM »
"Let us draw the curtain of charity over the rest of the scene"  - Mark Twain
