Author Topic: 02 cali stone air filter change?  (Read 6616 times)
Offline s1120
Re: 02 cali stone air filter change?
« Reply #30 on: February 19, 2019, 06:58:46 PM »
Well I got my parts in today so I set to work!  I got the new air filter in, and started in on the tank. I drained all the gas, and
Pulled the Percocet out to check for crud. A tiny bit of slime at the bottom but other then that nice and cleaned. Moat drain was clear so started putting it back together. It’s a bit of a bitch getting it all back, but with some
Extra hands from my 12 yo daughter I got it together. Lucky I had a old tube of Rubber lube in my toolbox from my old motorcycle days. Because those bushings were having none of sliding into the tank. Hoses connected, wiring toucked up out of the way, and all bolted down. Turned key looking for spraying fuel...  nope all good. Push starter button... dead battery!!! So a few hours charge and got it to turn over but no fire....WHAA!!!!  Another hour charge and she fired!!!!  Whoooo Hooooo!    Come on spring!!!!
Paul B
