Author Topic: Loop Spark Plugs  (Read 5598 times)
Loop Spark Plugs
« on: March 05, 2019, 03:19:52 PM »
The Chiltons manual calls for Marelli CW 225 or Bosch W225 T 2 plugs for my Eldorado.
Since the manual was printed in 1973 I'm thinking there might be something better today.
It's started cutting out on one cylinder so I'm going through things one at a time.
I think part of the problem may be the copious quantity of road salt this time of year, the roads are white with it.
Any recommendations for a resistor / non-resistor plug?
I'm fairly certain the leads and caps are non-resistor, I will check before I buy new plugs.
I'm still running the original coil with points, have points and capacitor on order.
Roy
« Last Edit: March 05, 2019, 03:25:44 PM by Kiwi_Roy »
Re: Loop Spark Plugs
« Reply #1 on: March 05, 2019, 03:42:10 PM »
My preference: solid (stranded metal) core wires, NGK LB05F (resistor) caps and NGK BP6ES plugs. I like either resistor caps or resistor plugs, but not both.
« Reply #2 on: March 05, 2019, 04:20:55 PM »
Thanks Charlie, I knew I could count on you.
Online pehayes
« Reply #3 on: March 05, 2019, 04:22:24 PM »
YMMV, but I swear by these:
http://www.guzzipower.com/Sparkplug-pehayes.html
Available on Amazon if you don't have a  local source:
https://www.amazon.com/Bosch-WR7DP-Platinum-Plus-Spark/dp/B000PKX6V0
Offline Furbo
« Reply #4 on: March 08, 2019, 03:18:04 PM »
Being a southerner, I prefer BPR8ES, a slightly cooler plug.     Or, autolite 63's which come in a handy 2 pack.
Killeen, TX
'96 Sport 1100
'72 N. Falcone
'72 Eldo
Eccl 9:9,10
Offline toolittletime
    • mysportgear.com
« Reply #5 on: March 09, 2019, 06:40:03 PM »
Looking mighty dapper there Roy..........gentle man's ride????
Tim
X-MSF Instructor
MGNOC 22710
12 Norge
2002 Cali EV
74 Eldorado
