Wheels for a 1979 G5 project...- Would I be correct to assume I could fit either spokes or cast rims? - Did they ever make a rear drum brake for a cast rim? - Do the T/T3 spokes fit the later final drives just the same as the earlier deep sump drives?At first I thought I'd go with cast rims because I assumed lower cost, and somewhat because they can be converted to tubeless, but a few of the cast rims I've come across seem rather pricey. I had assumed they be cheaper than the Borani rims.I think in a perfect world, I'd go with Borani spoked rims, but I suppose that's a taller order?Thanks!
I wonder if I can put a rear spoked drum brake on the G5 final drive?
Yes. You will need to weld a tab on the G5 swingarm for the tie-rod to attach to.
Ok thanks. Are there no issue with cush rubbers on the drum hub? Or do I have that wrong?
Pretty weld there, Charlie..
