Author Topic: What size Allen wrench v9 front axel?  (Read 1941 times)
Online bad Chad
« on: October 23, 2020, 04:43:25 PM »
For some reason the v9 has an axel that requires a hex head tool to extract.  I don't have one large enough, can someone tell me what size I need?
Online Tom H
Re: What size Allen wrench v9 front axel?
« Reply #1 on: October 23, 2020, 04:47:11 PM »
If you don't get an answer shortly. IF you have the tool kit it may have come with, there is one in there. Just measure it.
Offline moto-uno
« Reply #2 on: October 23, 2020, 05:27:09 PM »
  If you have a small selection of metric bolts , see which fits and the size of wrench that fits the bolt head is your answer . Peter
Online bad Chad
« Reply #3 on: October 23, 2020, 05:31:41 PM »
Tool kit does not come with one!  Crazy!
The metric bolt idea is clever, but still hope someone can save me the headache, not sure I have the right bolt.
« Last Edit: October 23, 2020, 05:35:41 PM by bad Chad »
Online Dirk_S
  • www.dirkshearer.com
  • Doodler of doodles
    • www.DirkShearer.com
« Reply #4 on: October 23, 2020, 05:39:34 PM »
V7s don’t come with it either, but I do know the V7 takes a 14 hex. Maybe the V9 is similar? Different part numbers unfortunately.
« Last Edit: October 23, 2020, 05:39:52 PM by Dirk_S »
Online Tom H
« Reply #5 on: October 23, 2020, 05:58:40 PM »
My EVT uses a 14mm. Now you have 2 bikes with 14mm.
Did a tool kit come with the bike? My EVT has one, there is a piece of hex bar that I always wondered what it was for. Latter found it was for the axle. I think there is a 14mm wrench to use with it.
Offline MotoG5
« Reply #6 on: October 23, 2020, 06:25:34 PM »
V9 is a 14mm also.
Nebraska MGNOC State Rep
« Reply #7 on: October 23, 2020, 09:04:27 PM »
The bike should have come with a short length of 14mm hex in the toolkit, mine did.
Use it with a 14mm wrench.
Online Dirk_S
« Reply #8 on: October 23, 2020, 09:11:53 PM »
What model bike do you have? I’ve seen that pre-early V7 owners got the hex bit in their tool kit, but my V7 II didn’t, and I’d be surprised (and a tad miffed) if any other V7 II, III, or V9 kit came with it.
Offline MotoG5
« Reply #9 on: October 23, 2020, 10:12:54 PM »
My V9 Bobbler did not have a hex bit in the kit. So happens that I had a 1/2 x 14mm socket bit in my tool chest. About seven bucks or so on Amazon or at your local hardware store.
Offline greer
« Reply #10 on: October 24, 2020, 05:41:47 AM »
The Nevada kit had the hex bit, the V7 II and Roamer do not.  The bolt head moto-uno mentioned makes a handy substitute, butt a couple of nuts together on the bolt and use a wrench on the inside nut to go lefty loosey, the outside nut to go righty tighty.
Sarah
Offline antmanbee
« Reply #11 on: October 24, 2020, 06:06:43 AM »
I bought a Bondhaus long 14mm allen wrench for about $7 and chopped off an inch or so to carry in my tool kit and I still have a usable allen wrench.
Alternatively use a 14mm bolt with a big pair of vice grips on the threads or a couple of nuts locked together on the threaded part of the bolt.
Online bad Chad
« Reply #12 on: October 24, 2020, 10:08:19 PM »
Thanks all.  Breva 11 kit has some hex tools, but none are 14mm.   Ordered one for $7.
« Reply #13 on: October 24, 2020, 10:22:33 PM »
I have a 2017 V7 III Special
Offline Cal3Me
« Reply #14 on: October 25, 2020, 12:03:17 AM »
Farm & Fleet has what you need Chad ,,,,,,
TMS
Offline Noguzznoglory
« Reply #15 on: October 25, 2020, 07:00:07 AM »
V9 is a 14mm also.
You can use a torx bit on an Allen head if that’s easier to find or you already have a set.
I believe a T60 is the size for a 14mm
93 750 Nighthawk
73 Honda CB350
73 Honda CL450
04 Breva 750
15 Norge
16 VERSYS 650
Online Dirk_S
« Reply #16 on: October 25, 2020, 07:11:41 AM »
Whelp. Guess that’s the price difference between Stones and Specials.
« Reply #17 on: October 25, 2020, 05:53:00 PM »
That might be possible, but that HAS to chew on the Allen socket a bit if you have to put any torque on it ... ?  Any port in a storm, but that doesn't sound like a good thing to do if you don't have to get home.
