sourcing female 3-pin connector (bike side) for ECU port - 2013 V7 Stone
Topic: sourcing female 3-pin connector (bike side) for ECU port - 2013 V7 Stone (Read 427 times)
lobazura
New Egg
September 22, 2025, 06:59:46 AM »
Hi everyone,
I'm a new member here and got my first Moto Guzzi a few weeks ago. A 2013 V7 Stone with 3900 miles, in really good shape with one previous owner.
I love the bike, riding is great, but it has some of what seem to be common fueling/running issues - needs to run for a minute or two or will stall out, jerky acceleration, popping on decel.
I went to find the diagnostic port with the intention of maybe remapping. After looking high and low and way too strenuously for the diagnostic port, what I found was, as far as i can tell, the diagnostic port was cut out and the wires capped off. Is that what I'm looking at? If so, Why???
Anyone seen this before? I have a few service records and it seems all the service was done at a shop, not by the owner.
Next question, anyone know where I could get this part - the bike-side female 3 pin connector? No luck finding the part in a web search, aside from buying a whole used wiring harness. Is that what I'd have to do? And, if I splice it in, will it even work? Weird times.
Last Edit: September 22, 2025, 07:13:24 AM by lobazura
Dirk_S
www.dirkshearer.com
Doodler of doodles
Re: sourcing female 3-pin connector (bike side) for ECU port - 2013 V7 Stone
Reply #1 on:
September 22, 2025, 07:36:45 AM »
Here are link to one on eBay and one on Amazon. Note the wire colors are different, and one of the wires isn’t necessary, but at least you have the connector body and could always change out the wires if you want.
EBAY:
https://ebay.us/m/U2Xoha
AMAZON:
url=https://a.co/d/7hdmtRx
There are some available for even cheaper if you search hard enough.
Last Edit: September 22, 2025, 07:53:46 AM by Dirk_S
Perazzimx14
Reply #2 on:
September 22, 2025, 08:10:51 AM »
I thing the wires that are wire nutted together are for heated grips, not the disgnostic port. In any event I get rid of the wire nuts and make a proper repair. Posi-Taps would be a huge upgrade 12-2 wire nuts.
2017 Road Glide Special
2020 Kawasaki KLX300SM
guzzisteve
"Just Ride It"
Reply #3 on:
September 22, 2025, 08:32:51 AM »
To find diag plug look in service manual, most likely tucked under something. Look in side covers, may have been rerouted by someone to different local.
Dirk_S
www.dirkshearer.com
Doodler of doodles
Reply #4 on:
September 22, 2025, 08:44:56 AM »
Good catch, guys. I didn’t consider that it actually might be the USB port. Makes more sense that someone would chop that connector off.
The diagnostic port is a 3-pin; the USB/AUX port is a 2-pin.
Last Edit: September 22, 2025, 09:02:51 AM by Dirk_S
Moparnut72
Reply #5 on:
September 22, 2025, 09:10:36 AM »
On a couple of my Guzzis they were tucked away in some of the strangest spots. Dig around, usually under something. Another sneaky way to make you take it to a dealer.
kk
Mopar or Nocar
2023 V100 Navale
2019 V7lll Special
MGNOC #24053
Dirk_S
www.dirkshearer.com
Doodler of doodles
Reply #6 on:
September 22, 2025, 09:15:02 AM »
OK, back to believing it’s indeed a diagnostic port in your photo. The diagrams in the service and owners manuals are difficult to read, so I just checked out Carl Allison’s wiring diagram, which you can find here:
https://www.thisoldtractor.com/guzzi007/schematics/2013_V7_Series.gif
…and here’s a screenshot:
Codes: 40 is the diagnostic port. B = Blue, V = Green, Bi = White.
Blue/White and Blue/Green appear to be the diagnostic port wires according to his colors. Carl’s drawings are pretty dependable (though I just emailed him about the B/V wire displaying as blue/purple instead of blue/green). I also don’t see a USB port in the diagram. Maybe my eyes are glazing over it, or maybe a USB port wasn’t included on the earlier Heron head V7 bikes.
Last Edit: September 22, 2025, 09:40:54 AM by Dirk_S
lobazura
New Egg
Reply #7 on:
September 22, 2025, 09:28:50 AM »
Thanks all for the replies!
Dirk - Really appreciate you looking into this. As you can kinda see in my photo , the two cut wires are blue/green and blue/white. Dun dun dun. This makes sense, because I definitiely had both side covers off and looked everywhere in there.
Thanks for the links! I probably didn't quite have the right search terms for it. With the color difference, not sure how to know which two of the wires to use, and which to connect to which on the bike?
Also, who would do this and why?!
Dirk_S
www.dirkshearer.com
Doodler of doodles
Reply #8 on:
September 22, 2025, 10:22:21 AM »
Maybe whoever worked on it didn’t feel like buying the cable connectors.
I couldn’t find any photos online to help figure out which wire goes into the respective slot. Hopefully someone on here with a 2013 model can chime in soon.
Perazzimx14
Reply #9 on:
September 22, 2025, 11:17:34 AM »
Gleaned from AF1's site. The plug does look like the 3 pin diag plug. The two wire nuts is what a bit confusing.
