Author Topic: Norge Toe Pegs (kinda short for me)  (Read 8004 times)
Offline Cool Runnings
« on: December 17, 2015, 03:29:25 PM »
Will these work?
This 1.5" eccentric offset toe-peg is designed to be used with your stock gear pedal to allow for a greater range of adjustment.
This toe peg features a toe lever (the part your foot actually touches) that is more than 2 inches long. For this reason, this part is probably better suited to commuter or touring uses.
This toe-peg is a great companion piece to the Knight Design Crosstrax Lowering Footpegs Kit
http://www.af1racing.com/store/Scripts/prodView.asp?idProduct=57158
Re: Norge Toe Pegs (kinda short for me)
« Reply #1 on: December 17, 2015, 04:00:52 PM »
Another possibility?
More than double the adjustable range of the stock toe piece.  Great for increased comfort, racing rearsets or lowered footpeg applications.
http://www.af1racing.com/store/Scripts/prodView.asp?idProduct=38427
Offline JeffOlson
« Reply #2 on: December 17, 2015, 04:43:34 PM »
I have the Knight Design toe pegs (and lowering foot pegs). They work great, but they do scuff up the top of one's left boot.  :wink:
2018 Vespa GTS 300
2016 Moto Guzzi Norge
2015 Vespa Sprint 150
2015 Vespa GTS 300
« Reply #3 on: December 17, 2015, 04:49:08 PM »
Thanks Jeff, the Russell showed up today (winter here). Come March I'm going to look into Knight Designs, should add even more comfort. Over 60 now and the legs/ feet ain't what they used to be.
Offline old as dirt 2
« Reply #4 on: December 17, 2015, 05:02:49 PM »
get some good heat shrink
2013 Norge
2008 MP3 500
bunch of other stuff that is long gone.
Offline Dean Rose
    • Twin Valley Riders
« Reply #5 on: December 17, 2015, 05:06:41 PM »
I need to buy some of those for my shifter and brake pedal.
While you're at it put some 1800 Goldwing pegs on it, makes it really a more comfortable bike.
Dean
Magnolia '02 EV
Sophia '06 Breva 1100
Offline JeffOlson
« Reply #6 on: December 17, 2015, 05:42:31 PM »
The only downsides to the Knight Design lowering foot pegs (not toe pegs) are:
  • They really do lower the foot pegs, so much so that one cannot corner as aggressively with them installed;
  • They have no rubber vibration dampers (so wear rubber-soled boots); and
  • The side stand hits and vibrates against the underside of the left foot peg.
They are more comfortable, though!
2018 Vespa GTS 300
2015 Vespa GTS 300
Offline MGrego
« Reply #7 on: December 17, 2015, 06:29:28 PM »
.... the Russell showed up today (winter here)...
CR, if you get a chance, post a pic of the seat on your bike.  I'm curious to see what a Russell looks like on a Norge --
Offline bad Chad
« Reply #8 on: December 17, 2015, 08:32:05 PM »
Put on the EU side stand, and problem solved.
1988 YX600 Radian
Offline JeffOlson
« Reply #9 on: December 17, 2015, 09:14:12 PM »
I actually prefer the USA side stand to the EU side stand. I prefer the larger foot and the greater lean angle for more stability when parked out on the farm (gravel if I am lucky; if not, grass, dirt, or mud...).
The solution seems simple, I just haven't tried it yet: a U-shaped rubber block stuck onto the thin bit of metal on the side stand that strikes the metal stop near the hinge.
Right now, I do not have the Knight Design bits installed, so no need to fiddle with rubber blocks just yet.
2018 Vespa GTS 300
2015 Vespa GTS 300
Offline PJPR01
« Reply #10 on: December 17, 2015, 10:15:34 PM »
The problem even with the rubber stop is you will still get some vibrations...dampen ed yes, but still somewhat noticeable that takes away the smoothness of the ride.
The Goldwing pegs are excellent...wider, flatter and slightly lower...really does the trick.  My Knight designs got installed and then removed after not being able to get a satisfactory solution...they are nice quality, but the side stand design just doesn't work with them and I don't want to shave off more of the bottom foot pad of the side stand.
Paul R
2015 Red/Black Griso
2008 Silver Norge
2002 V11 Scura
Offline JeffOlson
« Reply #11 on: December 17, 2015, 11:44:46 PM »
Which Goldwing pegs would fit the Norge? Is there a certain year or model?
Thanks for any info.
2018 Vespa GTS 300
2015 Vespa GTS 300
Offline PJPR01
« Reply #12 on: December 18, 2015, 08:30:00 AM »
Which Goldwing pegs would fit the Norge? Is there a certain year or model? Thanks for any info.
Credits for this tip to Tom Nova here on the board, I put these on my Norge, he had them on his Sport.  You'll also have to buy the Goldwing Springs to attach these, but no modifications are needed, just that they are slightly different than the Norge ones...I'll see if I can find where I bought those from.
http://www.ebay.com/itm/221484729980?ru=http%3A%2F%2Fwww.ebay.com%2Fsch%2Fi.html%3F_from%3DR40%26_sacat%3D0%26_nkw%3D221484729980%26_rdc%3D1
Paul R
2008 Silver Norge
2002 V11 Scura
Offline Dean Rose
« Reply #13 on: December 18, 2015, 08:52:16 AM »
Yep, that's them. You won't regret putting them on.
I had a set in a box for a few years and used the adjustable ones. Sure glad I changed to the Goldwing pegs.
Dean
Magnolia '02 EV
Offline MGrego
« Reply #14 on: December 18, 2015, 09:39:25 AM »
Put the goldwing pegs on my 2012 as well.  Also the goldwing springs.  Gains some needed knee room and it's nice wide peg.
I have been using a round 3M adhesive rubber block at the pivot point on the sidestand.  It has lasted several months.  It completely keeps the sidestand from touching the peg, so no vibrations at all.  I stuck the adhesive rubber block on there thinking it would be a temporary fix, but it has lasted quite a while.  I was thinking of putting a radiator hose clamp around the sidestand near the pivot point, and using the screw mechanism as the new "bump" to hold the sidestand away from the peg, but I haven't tried that yet --
Offline JeffOlson
« Reply #15 on: December 18, 2015, 10:06:32 AM »
So, these Goldwing foot pegs are actually lower than the Norge foot pegs? I'll have to give them a try!
Will the Norge springs not work with the Goldwing foot pegs?
2018 Vespa GTS 300
2015 Vespa GTS 300
Offline PJPR01
« Reply #16 on: December 18, 2015, 10:38:55 AM »
Hey Jeff...the Goldwing pegs are about 1/2 inch thinner, and since they are wider, a bit more comfortable as well.  You do have to get the Gold Wing springs, the Norge ones won't work...slightly different size/design.  Springs are cheap....easy to source.
Paul R
2008 Silver Norge
2002 V11 Scura
Offline MGrego
« Reply #17 on: December 18, 2015, 10:45:44 AM »
Yes- the Goldwing pegs are a little lower, I would say by about 3/4 of an inch, mostly due to having thinner rubber on them, but also set a little lower.
No, the Norge springs won't work, you will need to get the goldwing footpeg springs, (I found them at an online Honda parts shop @ $3.00 each), because the goldwing pegs use a right hand and a left hand spring, whereas the Norge right and left spring are identical. I have the packaging at home with the parts numbers for the springs I can give you if you can't find them --  I know this because I ordered 2 right hand springs not knowing the left side was different.  I'd be glad to send you my extra right hand spring to you if you think you can use it --
Offline JeffOlson
« Reply #18 on: December 18, 2015, 12:06:42 PM »
Thanks, guys! I will look into this. The Knight Design lowering foot pegs are great, but it would be nice to have rubber tops and not have the left one interfere with the side stand.
2018 Vespa GTS 300
2015 Vespa GTS 300
Offline frans belgium
« Reply #19 on: December 18, 2015, 12:53:34 PM »
Why not look for the Breva 1100 footpegs?  I think these are the same as the Norge ones, except 1 cm less thick.  I read that the Norge got thicker pegs to eliminate vibes, which I do not understand since neither (Breva or Norge) got any bad vibrations.
I've been thinking of swapping the Norge pegs with those of the Breva.  Getting older, cramped legs or knees become a nuisance.
Owned and sold: V65, Nevada, 2xCali, Breva 1100, Norge 8V, Breva 1100 with Squire sidecar
Currently own: V85 TT
« Reply #20 on: December 21, 2015, 08:21:39 AM »
Dean
Maybe I'll try these along with GL1800 Driver foot pegs?
GL1800 Driver Peg Lowering Bracket
Offline PJPR01
« Reply #21 on: December 21, 2015, 11:50:04 AM »
That's interesting...a little hard to tell from the picture but are those pushing the pegs out away from the body a bit?  The only issue there might be "alignment" of the boot with the shifter/brake pedals...but if they work, looks like they'd add some extra clearance for the knees.
Paul R
2008 Silver Norge
2002 V11 Scura
« Reply #22 on: December 21, 2015, 11:53:51 AM »
May have to find longer shift/ brake toe pegs?
Offline Dean Rose
« Reply #23 on: December 21, 2015, 12:19:43 PM »
I'd suggest that you try just the Goldwing pegs first.
Dean
Magnolia '02 EV
« Reply #24 on: December 21, 2015, 04:18:48 PM »
Dean
ok.
