Author Topic: BEST WAY TO REPLACE STELVIO BREATHER TUBES?  (Read 2355 times)
Offline Spuddy
« on: April 10, 2019, 10:43:28 AM »
Is there an optimal method to repair or replace cracked top end breather tubes on my Stelvio?  Both cylinders have cracked vents after 5 years use.
Spud
[/url]
[/img]
« Last Edit: April 10, 2019, 10:49:06 AM by Spuddy »
'13 Stelvio NTX
'07 California Vintage
'01 W650
Re: BEST WAY TO REPLACE STELVIO BREATHER TUBES?
« Reply #1 on: April 10, 2019, 07:29:06 PM »
There is no 'Best Way'. It's a prick of a job.
Offline lucian
« Reply #2 on: April 10, 2019, 08:33:04 PM »
My 09 griso had the same scenario,  the tubing will dry and crack  at that end near the engine heat more than along the rest of it's length. That plus the vibration at the clamp. I just trimmed off the end a smidge and re clamped them with screw type fuel line clamps. Don't over tighten them.  You could reinforce that  end first  with some shrink tubing but I didn't and two seasons later they are still holding in there.  Much easier to replace on the griso when the time comes , but for now we're good.
Also you could splice on some new tubing at that end with some  plastic or brass tubing connectors from any hardware store.if needed like these
https://www.usplastic.com/catalog/item.aspx?sku=62071&utm_source=criteo&utm_medium=retargeting&utm_campaign=lowerfunnel
« Last Edit: April 10, 2019, 08:42:31 PM by lucian »
« Reply #3 on: April 10, 2019, 08:43:02 PM »
After reading this, I knew there would be no sleep the night until I went out to the shop and had a close look at the breather tubes on my '09.
Thankfully, the rubber is still smooth and uncracked, but I believe that I will treat it to a little massage with some sort of rubber conditioner tomorrow ..... !!
Offline Zinfan
« Reply #4 on: April 10, 2019, 10:19:09 PM »
Here is a link to a thread on the ADVRider forums on how one rider did it.  https://advrider.com/f/threads/moto-guzzi-stelvio-merged-threadfest.113158/page-1431#post-33083522
Offline Demar
« Reply #5 on: April 10, 2019, 11:43:24 PM »
Use 7/16" ID hose. It will fit a lot better than the 1/2" ID hose.
2012 MG Stelvio NTX
2010 Bonneville T100
1953 Galletto 175
