Author Topic: Need help seting Jackal FI  (Read 1486 times)
Offline Burkslaw
« on: April 21, 2019, 07:06:29 AM »
I just acquired a 2000 Jackal, in very good condition except it spits back at very low throttle settings. Pulls well and cleanly when under load or at idle. It's only at very low throttle openings that any annoying spits occur. I think the previous owner may have tried to balance the throttle bodies, and they are now slightly out of whack. I can balance the airflow between cylinders but have no access to the equipment necessary to play with the TPS. Is it possible to get this thing running better without the high-tech Guzzi test equipment? Thank you.
Offline troyhamilton
  • Dr frankie
Dr Frankie!
1967 v7, gone
heldorado, gone
1975 850-t gone
1974 850-t gone.
2002 Jackal!
we need a tech section!
Offline Burkslaw
Re: Need help seting Jackal FI
« Reply #2 on: April 21, 2019, 08:11:15 AM »
Thank you!!!
Offline antmanbee
« Reply #3 on: April 21, 2019, 08:30:54 AM »
Bring it by and I will go through it with you. I got everything you will need.
Online wavedog
« Reply #4 on: April 21, 2019, 12:00:30 PM »
Another Guzzi owner in this part of Florida? If all four of us could get together on the same day.....but that would be like herding cats.
Offline Burkslaw
« Reply #5 on: April 21, 2019, 05:48:22 PM »
Many beers and pizzas await you if you can cure this off-idle spitting, Alan!
Offline Burkslaw
« Reply #6 on: April 21, 2019, 05:49:25 PM »
Offline antmanbee
« Reply #7 on: April 21, 2019, 05:56:52 PM »
Looks very clean. Nice find.
I'm confident we can cure it.
« Reply #8 on: April 22, 2019, 07:42:40 PM »
Dang! That's going to be easy beer and pizza. Why couldn't you be closer?  :evil: :smiley: Don't worry, Burkslaw.. you're in good hands.
Offline antmanbee
« Reply #9 on: April 22, 2019, 09:53:22 PM »
Chuck,
If you were closer I would be coming by often bringing beer and pizza to learn from one of the masters. Probably (hopefully) a little knowledge would rub off!
