Author Topic: TPS is bad. I need the H-D part number and info on Guzzi diag...  (Read 2798 times)
Offline troyhamilton
  • Dr frankie
My is supposed to be bad on my 2002 California Jackal, I am needing info on swapping to the HD part. And i dont know a yhing about Guzzi Diag, Help Please!...luddite learning!
Dr Frankie!
1967 v7, gone
heldorado, gone
1975 850-t gone
1974 850-t gone.
2002 Jackal!
we need a tech section!
Offline Joliet Jim
  • Justus Esto, Et Non Metue
Re: TPS is bad. I need the H-D part number and info on Guzzi diag...
« Reply #1 on: March 05, 2019, 05:14:02 PM »
Wildguzzi.com - a lot of tips for old Calis
TPS Tip from Jeremy Ogden:
Here's a tip for California style bikes' TPS... 27271-95 HD (TPS) I checked and A dealers price is $126.00. They were happy that they could get one for $40.00.
Swapping Tip from Wildguzzi:
Here's some 15 minute TPS instructions I have sent to several people who have changed their TPS this way successfully.
1. Mark with a pencil, the line on the current TPS in reference to your throttle body.
2. Get a digital volt meter (analog will do no good for this application), set it to the lowest DC setting on there, usually MV.
3. Pearce the 2 outer cables that go to the TPS, and take the reading (ignition on).
4. Turn off ignition and pull the old TPS off.
5. Put the new one on, and line up the line on the TPS with the line you made on the throttle body.
6. Snug the bolts, but don't tighten. You'll still need to turn the TPS.
7. Rotate the TPS (key on) until you have your old reading.  A hair width of a turn will make a HUGE difference. I used a screwdriver and tapped it until I found the reading. Its a picky booger.
8. Tighten the bolts.
9. Start the bike.
10. Take off.
« Last Edit: March 05, 2019, 05:15:11 PM by Joliet Jim »
2002 Cali Stone "Moby Dick"
2003 Buell Blast "Pegasus"
Just memories
The Psycho Chicken
The Fire Demon
Thumper
« Reply #2 on: March 05, 2019, 05:25:45 PM »
here's an aftermarket supplier.  It's supposed to be the correct replacement part, not the Harley one.
http://ca-cycleworks.com/pf3c
My experience is that I've had the Harley part fail and this one.  I suspect there is poor quality control with all these replacement parts.
  • Dr frankie
« Reply #3 on: March 05, 2019, 05:53:04 PM »
thanks. this helps! :cool: :boozing:
Dr Frankie!
1967 v7, gone
heldorado, gone
1975 850-t gone
1974 850-t gone.
2002 Jackal!
Online John Croucher
« Reply #4 on: March 05, 2019, 06:06:48 PM »
The TPS will come apart very easily.  Take it off, pop the cover off and inspect.  I found one I replaced to have the contacts bent on one tab and part of the other tab missing.  How this happened, anyone's guess.  Bike only had a 6,500 mile on it.  It ran much better after replacing with the OEM part.
While you have it off, use a multimeter to test if the reading changes consistently and smoothly thru the range.  It may just be dirty.
Online Mackers
  • Five miles or 1000ft...how hard can it be?
    • Motoguzzimackers Moto Guzzi Diaries
« Reply #5 on: March 05, 2019, 06:35:42 PM »
I changed it on my '01 Metal Stone many years ago.  Worked like a charm.
http://motoguzzimaintenance.wikifoundry.com/page/Moto+Guzzi+Stone+TPS+Replacement
Raymond Massey:  "No doctor, I think this calls for something special.
                  I think, perhaps, the Melbourne Method!".
Peter Lorre:  "Not the Melbourne Method!!  Please!!"
            - Arsenic and Old Lace, 1944.
('06 Breva 1100 and '02 Cali EV - '01 Metal Stone deceased).
« Reply #6 on: March 05, 2019, 06:37:04 PM »
And you don't need Guzzi Diag, just set the TPS for 150 mV with the idle stop backed right off so the butterfly is closed then don't touch it again.
Later when you set the idle speed at 1100 RPM it will end up about 400 millivolts.
Some procedures tell you to set the idle screw to give you the millivolts but it's really the idle revs you are setting.
Set the revs and don't worry what the mV is saying at idle speed.
« Last Edit: March 05, 2019, 06:57:41 PM by Kiwi_Roy »
Offline flower_king001
« Reply #7 on: March 06, 2019, 11:09:17 AM »
I replaced mine several months ago using this one:
The TPS that went bad was a Harley...after replacing with the PF3C from CycleWorks my bike never ran better.
1971 BMW R90/5
1998 Moto Guzzi 1100 EV
2005 BMW 1200 RT
2007 BMW 1200 GS
2007 Moto Guzzi Breva 1100
  • Dr frankie
« Reply #8 on: March 06, 2019, 01:10:32 PM »
thanks guys!
Dr Frankie!
1967 v7, gone
heldorado, gone
1975 850-t gone
1974 850-t gone.
2002 Jackal!
