Author Topic: Sport 1100 Sidestand  (Read 4051 times)
Offline simaster
« on: October 28, 2019, 02:54:17 PM »
My '96 Sporty's side stand snapped while being shipped to me in AZ.  It appears to have bent right before it snapped.  I have scoured the world for a while now looking for a replacement and have come up empty handed.  I'd be interested to get your thoughts on how you would address this.  What would be your 'Plan B' if you couldn't find a replacement?  Any wisdom you may have for me is welcomed.  Thank you
Offline malik
Re: Sport 1100 Sidestand
« Reply #1 on: October 28, 2019, 04:18:16 PM »
If it's mounted as on the carbed Sport, I'd guess you were lucky the stand snapped, rather than the casting on the timing cover. I'd seize the moment & fix a sidestand to the pork chop - a chap in NZ found one from a Suzuki that work well, though you'd have to give up using your hand to deploy it & just use your foot.
Offline Murray
« Reply #2 on: October 28, 2019, 05:22:16 PM »
Daytona, Cenauro and V11 Sport and V11 Lemans all had a similar setup which might broaden your search.
« Reply #3 on: October 28, 2019, 06:08:35 PM »
Increase your search to include V11 Sport / LeMans and Daytona.
Also, never ship with the sidestand deployed!
« Reply #4 on: October 28, 2019, 07:01:38 PM »
^^^^ yeah, what they are saying. It's fragile. Seems like I remember Harper's having some. Have you checked?
Offline simaster
« Reply #5 on: October 29, 2019, 07:37:49 PM »
Thanks Chuck - Yes, I have checked harpers.  Unfortunately it's "on backorder"
Offline simaster
« Reply #6 on: October 29, 2019, 07:40:39 PM »
Yeah, I left it in the hands of a "professional" and got it back with a snapped side stand and some paint damage.  Sweet!
Offline MedicAndy
  • Stable Companions:
  • It's not always easy being me!
« Reply #7 on: October 30, 2019, 07:52:27 PM »
I'm pretty sure that I have a couple of side stands lying around the barn. I'm going to look for them this weekend and send you a couple of pictures to see if you are interested in one. Can you post a picture of the actual part that is broken and needs to be replaced? I'm pretty sure that it is the actual rod and not the mounting bracket that is damaged, but I could be wrong.
Andy
96 Suzuki GSX-R 1100W
95 MG 1100 Sport x 1
96 MG 1100 Sport x 2
97 MG 1100 Sport x 4
Offline simaster
« Reply #8 on: October 31, 2019, 01:59:46 AM »
Andy
Thanks for the reply Andy.  I appreciate you looking into it for me.  Here are a couple pics:
Offline Devildog
« Reply #9 on: October 31, 2019, 06:57:15 AM »
Metal fatigue or impact stress fracture?
I'll inspect mine carefully, something else to worry about.....
'93 Daytona 1000
'95 Sport 1100
2002 Aprilia RSV Mille R
'10 GasGas e250 FE
Offline simaster
« Reply #10 on: October 31, 2019, 11:21:32 AM »
I’m assuming stress.  The shipper tied it down with the stand extended.  I’m assuming he hit a few bumps along the 2k mile journey that were too much for the stand.  Amateur hour...
Online Motormike
« Reply #11 on: October 31, 2019, 11:45:22 AM »
 Like you, I had a clown shipper (Motorcycle Shippers...STI) strap my Multistrada to the pallet with the bike's side stand down.  This has been know to crack the sump.  I got very lucky.  The stand mounting bolts worked loose, but I think the plywood pallet surface had just enough give to prevent a case fracture.  Ducati owners manuals even go as far as to warn against putting your full weight on the bike with the side stand deployed.
Offline jcctx
« Reply #12 on: October 31, 2019, 11:50:32 AM »
Could a good welder not repair it?????
jwinwi
« Reply #13 on: October 31, 2019, 11:55:56 AM »
Making it out of Aluminum was a bad idea; it flexes quite a bit. If I had it welded I'd put a sleeve over as much of the length as possible.
Offline malik
« Reply #14 on: October 31, 2019, 01:33:17 PM »
Perhaps the flex is a design feature rather than a problem. I would think an aluminium welder would be able to fix that. Take the opportunity to lengthen it an inch or more. And add a bigger foot.
« Reply #15 on: October 31, 2019, 02:03:00 PM »
Yeah, it's repairable.
Offline pressureangle
« Reply #16 on: October 31, 2019, 06:28:32 PM »
I don't suppose there's any interest in having new legs made, given that the minimum order from the forge is 400...plus machining.
Still in the works is an improved sidestand bracket, which may or may not see the light of day for the same reason.
Offline simaster
« Reply #17 on: November 01, 2019, 11:37:09 AM »
That's my next step if I can't find one in the near term.  The only issue is there is a bend in the material.  Hopefully a good welder/fabricator can address.
Offline Devildog
« Reply #18 on: November 01, 2019, 12:27:08 PM »
The bikes do seem to lean over a bit too much, which puts more weight and stress on the stand?
'93 Daytona 1000
'95 Sport 1100
'10 GasGas e250 FE
Offline simaster
« Reply #19 on: November 03, 2019, 12:35:51 AM »
Agree.  Poor design.
