Author Topic: Breva won’t take throttle  (Read 2810 times)
Offline Phil/TX
« on: September 19, 2020, 10:06:23 AM »
I replaced the fuel lines du to a leaking plastic fitting, replaced fitting with a brass one. I rode to get gas, 10 mile ride, ran smoothly, and accelerated fine. Filled up 3.5 gal of premium, on the way home, suddenly would not run above 5000 rpm. When I turned the throttle at 5000, it bogs down. The valves have been set recently, new spark plugs, battery charged, just normal guzzi reactions.......... ..i didn’t even say anything bad to her?
"You will seldom regret what you have done, but you will always regret what you have not"
2024 V7 Stone Corsa (850)
2024 Triumph Speed 400
20 Guzzi V85TT Coast Guard (super chicken)
23 V100 S Mandello ( wing man)
Offline Zoom Zoom
Re: Breva won’t take throttle
« Reply #1 on: September 19, 2020, 10:10:12 AM »
Your description makes me think partially plugged fuel filter or a kinked line preventing adequate flow.
Zz
Offline Phil/TX
« Reply #2 on: September 19, 2020, 10:28:03 AM »
I’m thinking that also Zoom zoom, but why it ran so good going to the gas station, and so poor coming home?
« Reply #3 on: September 19, 2020, 10:41:37 AM »
When it bogs down, does it misfire?
That could be bad plug leads.
If it just loses power but doesn't miss I would agree plugged filter.
Perhaps your fresh gas wasn't so fresh after all.
Does the Breva have a plastic or metal tank?
Internal or External pump/filter?
« Last Edit: September 19, 2020, 11:26:12 AM by Kiwi_Roy »
Offline Phil/TX
« Reply #4 on: September 19, 2020, 12:26:09 PM »
May have found the problem, battery low, when I got it back, I put the charger on it and it is still not charged after an hour. Fortunately I had the for sight :thumb: to order a battery about three days ago. When the battery is charged, I will monitor the voltage till the new battery gets here. Then I will check the charging system .
Offline malik
« Reply #5 on: September 19, 2020, 02:54:28 PM »
I know a deteriorating battery can cause all sorts of weird effects, and it's definitely worth trying a new one, but I'd be looking at the fuel, being the last change before the trouble. Here, down under, fuel composition is different, and I have found that at least one brand of premium doesn't work very well in the 2TB. I presume that the additives in it, designed for high performance auto FI systems are not appropriate for our simpler systems, even presuming the fuel itself is clean. Then, FWIW, I have found that there is no significant difference in using unleaded 91 or 95 either. But different countries, different fuels. I thought one feature of the Heron head design was tolerance for poor quality fuels.
Do note that I have found that balancing the throttle bodies improves performance and fuel consumption. How long is it since yours has been done? While doing that, you could check the operation of the TPS for flat spots. The one on my Classic had a flat spot between 3,400 & 4,000rpm. Replacing the TPS got rid of the persistent missing at around 4,000.
Good luck.
GeorgiaGuzzi
« Reply #6 on: September 19, 2020, 10:51:10 PM »
Sounds like there may be excessive water in the stations fuel. Too much water / bad gas acts like it’s really leaned out. As least in my experience.
Offline moto-uno
« Reply #7 on: September 19, 2020, 11:12:21 PM »
  ^ +1 , Peter
Offline lucky phil
« Reply #8 on: September 19, 2020, 11:41:13 PM »
If the battery doesn't change the symptoms dont discount a kinked breather hose under the tank, although from my experience with a V11 Sport it usually causes the tank to pressurise and expand you never know. The topped up tank means less air in the tank so less capability to cope with a blocked breather hose. Just postulating since you've had the tank off.
Ciao
« Last Edit: September 19, 2020, 11:44:01 PM by lucky phil »
Offline Phil/TX
« Reply #9 on: September 20, 2020, 01:47:41 PM »
Charged the battery, starts and takes throttle, but only 13.5 volt at the battery. So I think I should get 14.4 voltes when running. So is it:
A) the battery?
B) voltage regulator?
C) Alternator?
Offline malik
« Reply #10 on: September 20, 2020, 05:43:39 PM »
13.5 sounds fine to me.
« Reply #11 on: September 20, 2020, 05:48:58 PM »
It's fine until it starts dropping on you, ride it & watch it.
Offline lucky phil
« Reply #12 on: September 20, 2020, 07:12:23 PM »
A) the battery?
C) Alternator?
No you should be getting 14.2-14.4 range revving the engine. 13.5 reg output is low. I dont think it will be causing your issue though. Sounds like the reg to me. Check all the reg connections esp to the alt. I've just replaced mine with a EME unit.
If your bike has a hard wired headlight take it for a ride with the headlight fuse pulled or if not have the lights off. That battery voltage should be fine to run normally so it should rev out ok.
Ciao
« Last Edit: September 20, 2020, 07:15:53 PM by lucky phil »
« Reply #13 on: September 21, 2020, 04:52:55 AM »
A bit low for me Mal.  13.6 can be just a fully charged good battery.  1.4.2 at least and 14.4 better (on a fully charged battery.  It will be lower if battery voltage is low to start with.)
« Reply #14 on: September 21, 2020, 04:56:51 AM »
Phil, you obviously have had the tank off to replace the fitting.  If not the filter, I would strongly suspect kinked lines.
When it has the limited revs, opening the gas cap and trying again could eliminate a kinked breather.
Offline lucky phil
« Reply #15 on: September 21, 2020, 07:20:33 AM »
Yes should work.
Ciao
Offline Bisbonian
  • Living the Dream
« Reply #16 on: September 21, 2020, 01:23:06 PM »
A) the battery?
C) Alternator?
Are you using a standard voltmeter or the one built into the bike?
The one on the bike reads about a volt low in my experience.
