I replaced the fuel lines du to a leaking plastic fitting, replaced fitting with a brass one. I rode to get gas, 10 mile ride, ran smoothly, and accelerated fine. Filled up 3.5 gal of premium, on the way home, suddenly would not run above 5000 rpm. When I turned the throttle at 5000, it bogs down. The valves have been set recently, new spark plugs, battery charged, just normal guzzi reactions.......... ..i didn’t even say anything bad to her?
Charged the battery, starts and takes throttle, but only 13.5 volt at the battery. So I think I should get 14.4 voltes when running. So is it: A) the battery?B) voltage regulator?C) Alternator?
13.5 sounds fine to me.
Phil, you obviously have had the tank off to replace the fitting. If not the filter, I would strongly suspect kinked lines.When it has the limited revs, opening the gas cap and trying again could eliminate a kinked breather.
