Author Topic: v9 Roamer bar risers?  (Read 1245 times)
Offline bad Chad
« on: March 17, 2021, 01:59:17 PM »
I want to raise the bars.   I bought a set of bilt 22mm risers that seem pretty nice, however the bolt center on the risers are 32-36mm,  and they don't fit.  As I measure, Guzzi chose to use a 40mm distance center to center!  Anyone know where I can find risers with a 40mm bolt pattern?
Offline Joliet Jim
  • Justus Esto, Et Non Metue
Re: v9 Roamer bar risers?
« Reply #1 on: March 17, 2021, 09:33:33 PM »
I don't know whether this would work on the v9 or not, but do you remember when people were putting chrome socket underneath there with a longer bolt into the top trouble clamp? Would that possibly work on the v9?
ZZ
Craftsman forget the size but I've got two of them from the Stone
2002 Cali Stone "Moby Dick"
2003 Buell Blast "Pegasus"
Offline greer
« Reply #2 on: March 19, 2021, 05:21:04 AM »
Shaft collars work well, too.  A couple of them stacked together will get you right at an inch.
Sarah
Offline Dimitri_Harkov
« Reply #3 on: March 19, 2021, 11:09:15 AM »
LSL has bar risers for the V9:
https://www.lsl.eu/121-m021?___store=en
But I guess shaft collars will do the trick for less $$$.
Cheers,
D.
2020 V7 III Stone Night Pack
Offline bad Chad
« Reply #4 on: March 19, 2021, 03:24:44 PM »
Thanks, but those are bobber clamps, a little different.
Shaft collars?   Is that like a cock ring?   Just kidding, but really, what are shaft collars?
« Reply #5 on: March 19, 2021, 03:29:20 PM »
Those fit both the Roamer & Bobber.
Offline Joliet Jim
« Reply #6 on: March 20, 2021, 08:23:23 AM »
when you were little they dropped you on your head a few times didn't they?
Offline bad Chad
« Reply #7 on: March 20, 2021, 11:10:49 PM »
All resolved.  Thanks for the good ideas.   Used a rat tail file to increase to bolt pattern, worked like a charm.
