Author Topic: NGC Recommendation for rustproofing inside boat trailer rails  (Read 1200 times)
Offline Ryan
I bought a little Olympian for lake and small river fishing. It needs a little help, and the trailer is a little rusty. All surface at this point, no heavy scales or holes. I dismantled it, and will strip the old paint and rust off and repaint it, but what can I do about the interior walls? Anyone with experience with this have a creative solution?
Offline wrbix
Re: NGC Recommendation for rustproofing inside boat trailer rails
« Reply #1 on: July 04, 2021, 06:18:03 PM »
Airplane maintenance commonly employs CorrosionX spray inside enclosed spaces as corrosion inhibitor- don’t know about applications to rust. Might call the company.
Bill in VA, sometimes FL
"Eschew aphorism"
LeMans IV - "Giulia"
Lario - "Giulietta"
V50III cafe'd - "Leggera"
‘77 Convert - “Sofia”
Classic Mini
‘60 Austin Healey Sprite
Caterham Super Seven Sprint
‘13 Audi TTRS
Grumman AA5B (sold)
Offline reidy
« Reply #2 on: July 04, 2021, 06:23:41 PM »
There is a product called penetrol. I would look into that as it is easy to get and effective.
Steve
Offline Madtownguzzi
« Reply #3 on: July 04, 2021, 06:29:51 PM »
Check out the Rust Store. I would use Fluid Film with an undercoating gun set up to coat rocker panels and frame rails.
https://www.theruststore.com/Rust-Removers-C1.aspx
https://www.theruststore.com/Fluid-Film-C67.aspx
https://www.theruststore.com/Fluid-Film-Undercoating-Gun-P492C67.aspx
Randy S.
98 V11 EV
05 HD Electra Glide Classic
Madison, WI
Offline Ryan
« Reply #4 on: July 04, 2021, 10:33:26 PM »
Ordered something from rust store. If it rocks, I'll share info.
Offline s1120
« Reply #5 on: July 05, 2021, 07:00:49 AM »
Eastwood sells a inside frame coating. Has a long flexible wand to get to get into enclosed frames. Seems to work well.
Paul B
Offline Sykestone8886
« Reply #6 on: July 05, 2021, 08:05:30 AM »
I have my truck undercoated with fluid film from a local guy,holds up well to our crappy winters. I also sprayed my utility trailer and snow plow with spray cans I bought at the auto parts store, I recommended it.
Offline mechanicsavant
« Reply #7 on: July 05, 2021, 12:10:43 PM »
I’m +1on fluid film sprayed with an undercoating gun . It comes in 2 colors , black or snot yellow. Personally I like the soap & water clean up also I’ve let it sit in the spray equipment for 6 months with no ill effects!
Offline larrys
« Reply #8 on: July 06, 2021, 07:49:42 AM »
Used boat trailers are a crapshoot. If it is rusty on the outside, it is just as rusty if not more on the inside. You won't know until it starts breaking up when you're going down the road. YMMV.
Larry
'13 Monster 1100 EVO
'95 Cal 1100
'68 Bonneville
MGNOC 7248
Offline Ryan
« Reply #9 on: August 07, 2021, 06:09:11 PM »
Larry
Yup. That's why I tore it apart and started this project to begin with. Now that the paint is off, I can see what I have to work with and it is pretty solid. Worth the effort, as treated and painted it should last.
Online John A
« Reply #10 on: August 08, 2021, 11:34:38 AM »
I like to use a conversion product, Ospho is one that is sold by Ace hardware. Converts rust to a passive oxidation which acts like a primer that should be painted over because water can make it activate causing a white fuzz to form. But it does stop the rust. On tools it works to put oil on after the treatment is dry. Inside a frame rail it would be easy to apply, followed by your choice of paint or oil.
