Author Topic: Tachometer Compatibility – 96 California 1100i and 97 EV  (Read 2010 times)
Online ChrisG
« on: August 22, 2022, 10:30:59 AM »
I have a 96 Cali 1100i.  The tach is not working (just quit). My part, GU2976250, is listed for 94-97 California 1100i.
Part #GU03767200 is listed for the California EV from 97-2000I. I found one available. It is a different face color. Is this tach compatible with my 1100i?
Alternatively, any recommendations for tach repair?
Chris
Current: 2022 V7 Stone 850
Gone: 96 California 1100i, 2008 Breva 750, 06 Breva 1100, 2007 Sportster,1971 BMW 75/5, 1969 Triumph Trophy
Forgotten: A couple Hondas, a Yamamaha, ??
Online ChrisG
Re: Tachometer Compatibility – 96 California 1100i and 97 EV
« Reply #1 on: August 22, 2022, 11:11:18 AM »
I think I answered my own question - Guzziology has them as different sizes - the GU2976250 is 100mm, the GU03767200 is 80mm, so it wouldn't fit right (even if it is compatible electrically).
So - repair suggestions?
Chris
Offline guzzista
« Reply #3 on: August 22, 2022, 01:01:30 PM »
Chris
Foam or rubber weather stripping to take up the gap in the housing or trade it with someone off of the forum list.
Online PeteS
« Reply #4 on: August 22, 2022, 01:08:20 PM »
Depends what is wrong with it but likely not worth a repair. Assuming its electronic its basically a voltmeter. The movement is very fragile and breaks easily. Speedos are different and may be worth repairing. Check out aftermarket ones. I made a new mounting plate for my EV to fit a aftermarket tach.
« Last Edit: August 22, 2022, 01:11:30 PM by PeteS »
Offline tris
« Reply #5 on: August 22, 2022, 01:38:21 PM »
Might be worth checking out speedhut
https://www.speedhut.com/
1993 TW125 "POS" - Resting
Offline bigbikerrick
« Reply #6 on: August 22, 2022, 01:54:59 PM »
Like Tris suggested, Soeedhut is the way to go.
I put a speedhut tach in my EV, and it works flawlessly. Great company to deal with. I also installed one in a Cal II I had.
Rick.
« Reply #7 on: August 22, 2022, 04:12:14 PM »
+1 on Speedhut.   :thumb:
Online ChrisG
« Reply #8 on: August 24, 2022, 08:17:26 AM »
Thank you all. I'll see if Joel Levine can fix it, and if not, Speedhut for a replacement.
