Author Topic: QQ- Sealant on Breva Pump Seal?  (Read 2978 times)
Offline kfz
« on: June 08, 2026, 05:48:17 AM »
Hello, I say good morning to you all,
Should I use some sort of Sealant for my Breva1100 fuel pump the rubber seal. Or just fit it dry?
Kev
« Last Edit: June 08, 2026, 07:40:24 AM by kfz »
Offline malik
Re: QQ- Sealant on Breva Pump Seal?
« Reply #1 on: June 08, 2026, 07:43:24 AM »
I've never used sealant or come across anybody else who does on the fuel pump seal. Dry works fine.
Offline kfz
« Reply #2 on: June 09, 2026, 12:42:54 PM »
Thanks Malik, there was some sort of sealant on there (not original filter).
« Reply #3 on: June 09, 2026, 01:20:06 PM »
Loctite #518 is red goo that is recommended for Aprillia pump plate O ring, stops the fuel. I use it on petcock nuts going to tank, they never leak. Same with all the fuel pump plate rubbers. Re-smear & reuse.
